Super Wide Singles
rtz549
If the tire makers made these tires in sizes that would fit dual wheel pickups; would you run them?
The semi tires don't look big on a semi; but they are apparently 40" tall.
These tires are rated at about 10,000 lbs each.
I think they would work great for driving on sand?
Do you think OEM's would ever start offering those tires as stock or at least an option? I'm surprised we haven't seen them in smaller sizes by now.
Semi truck tires:
http://www.thedieselgarage.com/forums/showthread.php?t=96850
28 REPLIES 28
msiminoff
YES! If there were a true super-single setup available... that used a 17", 18" or 20" wheel and in a tire size that would fit on an un-lifted pickup truck (ie. 34" diameter or less) and with a load rating that met my needs (5000lb+) and matched the diameter of an available front tire... I'd buy them in a heartbeat, regardless of cost!
Unfortunately, I don't believe that such an animal exists. I have spoken with representatives from several tire manufacturers (Michelin, Falken, & Toyo) and they have all said that they don't think there is a market for them. But if somebody were willing to front the development and production cost, there's no question that a real truck-camper-specific-super-single could be made.
There are some tires that come pretty close, like the MT's that Jefe runs, and the 37'x12.5-16.5" military hummer tires (with beadlock rims!). Sadly, I have yet to find a tire/wheel combo that addresses all of my needs 😞
I have been using 19.5's for the past 8 years and I am a huge fan of them! However 19.5's will never be "great for sand". Good sand performance is dependent upon being able to run low tire pressure. Increasing tread width without lowering the pressure does not solve the issue. The lack of a true bead-bump on 19.5 (& 22.5") wheels means that the tires cannot be aired down without the risk of de-beading. The stiff sidewalls don't help either.
Keeping my fingers crossed that I'll find the perfect tire someday.
Cheers
-Mark
'04 Alpenlite Saratoga 935, 328W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins,Vision 19.5 w/M729F's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Rancho RS9000XL
The Overlhander Blog
2oldman
Boatycall wrote:
You would then need 2 different spares-normal and super single. Where would you keep a second spare?
Don't carry one.
Boatycall
'15 F450, 30k Superhitch, 48" Supertruss, 19.5's, Torklift Fast Guns
'12 Eagle Cap 1160, 800watts solar, Tristar MPPT, Magnum Hybrid 3k Inverter
'15 Wells Cargo 24' Race Trailer, 600 watts Solar, TriStar MPPT, Xantrex 2kw inverter
'17 Can Am X3 XDS Turbo
ticki2
rtz549 wrote:
Also since many complain about the stiff ride from a 1 ton truck; I'm surprised the OEM's don't put airbags under the seats or cab like they do on semi trucks. I'd also like to see them take some design ideas from semi truck frames and apply them to the flimsy pickup frames so they can have some real hauling capacity.
Maybe it's the P rated tires? Or the light duty wheel ratings? Or the car axles they put in them?
For the asking price of a new truck; they really should offer a lot more.
Lets see if I've got this . You want a 1 ton truck that can carry 4 tons , ride like a sedan and cost less . I'd like one of those .
The only trucks I know of with P rated tires are 1/2 tons .
It would be nice to find some wide heavy duty wheels and tires in standard sizes .
'68 Avion C-11
'02 GMC DRW D/A flatbed
woodhog
Best not to task their brains with too much too quickly, it is only in recent years that they figured out how to make their frames stronger and a few things like noticing that there was nothing substantial to tie things down to in the boxes.:)
By 2020 they might realize a truck rides rough and a car seat is no good !!
2004.5 Dodge 4x4 SRW Diesel, 245/70R19.5 Michelin XDS2, Bilstein Shocks
Torklift Stable loads, BD Steering Stabilizer Bar, Superchips "TOW" Programed,Rickson 19.5 wheels
2006 8.5 Northstar Arrow, 3 Batteries 200 Watts Solar,
12 Volt DC Fridge.
Super_Dave
Do we know what size rims the Ford in the picture has?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
2oldman
Then they would cost as much as a real truck.
Golden_HVAC
smkettner wrote:
rtz549 wrote:
Narrow the rear to make like an SRW 350/3500 and I am in :B
I was just noticing the 4 wheel drive on this truck. If the rear tires are more than about 3/8" taller than the front tires, there could be problems in the sand. On ice and snow, then the rear tires can easily spin faster than the front ones, and not cause a huge problem, but in sand, the center differential can cause problems if trying to spin the rear tires say 625 times per mile while the stock diameter front tires are spinning 665 times per mile.
I hope they are the same diameter! It looks that way. But a string around the outside of each tire, and making sure that they are within about 1/2" (outside diameter length) is the only way to make sure there will not be center differential damage.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
Golden_HVAC
They do make super singles for the 19.5" rims and some are rated well above 7,000 pounds required for a 'dually' pickup. The 4X4 F-650 has super singles on them (aftermarket) and are huge, with treads about 1.5" deep! They look about 15" wide.
The super singles in the picture at the top on the blue class 8 truck are probably rated around 10,000 pounds each, to match up with the normal 34,000 pound axle rating for the two rear axles. (Combined 2 axe weight rating is normally about 34,000 pounds on a class 8 truck).
Cement trucks have been using super singles for many years.
Fred.
Escapees.com
Wheelholder
Those super singles you are talking about only come in 22.5 rims. They save fuel, which is why truckers use them. I have heard complaints about hydroplaning in the rain. The cost is actually less than buying 2 tires on the big rig. After the initial cost of buying 4 new rims to hold the tires, there is a cost savings.
I would imagine one of the reasons no air ride seats is the air compressor. A big rig uses air for a multitude of reasons(brakes, works the splitter on the transmission, supply the trailer with air, etc.) If the oem's would put a built in compressor like a big rig, it would make sense to air ride the seat.
2008 Silverado crew cab Duramax/Allison
2008 Lance 830
Deb_and_Ed_M
That's a sexy-looking truck! Looks like it's ready for the quarter-mile 😉
Ed, Deb, and 2 dogs
Looking for a small Class C!
rtz549
time2roll
Buzzcut1
Nomad II
Nomad II
Jefe runs super singles on his truck
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
