Tank Problems
Yngrver
The dreaded "tank problem"s....
I am having trouble with both my gray tank and my black tank.
1) My gray tank is continuously clogged. I have to take a plunger to it about once a month to empty it. I have to plunge both inside the tub and on the outside where the valve is. When the water comes out there is a big gush and these white things come out with the water. The debris looks like big white pieces of deodorant though it is not deodorant (just looks like it). I am guessing it is big pieces of grease.
2) This morning when I went to flush the toilet I noticed that it appeared to be clogged/full. I went outside and opened the valve to empty it. There was a nice flow into the sewer line for about 5 seconds and then a slow trickling sound of water. I went back inside to the bathroom and flushed the toilet and the toilet was still full. The solids had not moved but it appeared that the liquids had not moved either because as I was flushing I could see the solids moving and floating around. I did not leave the valve open anytime so I am assuming that there is not pyramiding going on.
Any suggestions or ideas for both of these issues? Do I need to have someone come suck all this "crap" out? I saw where some people mention different chemicals I can buy. Thanks for the help.
2005 Saturn Ion (not a pulling vehicle)
2005 30 ft Travel by Recreation by Design
22 REPLIES 22
mhardin
The white stuff in the grey tank is grease. Find a product that will eat or melt the grease and that problem will be solved unless you dump more grease down the drain.
2013 Ford F-350, 4x4, Crew Cab, Long Box.
2001 Jayco Eagle 266 FBS.
2014 Heartland Elkridge 37 Ultimate.
Yngrver
Thanks for the tips....I have an update.
I did buy the back flush elbow to at least give it a try but I don't have a clear shot to either tank so it really doesn't do any good.
I bought a chemical that the lady at Camping World said would work on the black tank but not the grey tank. The chemical ended up working a little for the gray tank but not at all for the black tank.
I left the chemical in both tanks for about 4 or 5 days. I did nothing for the black tank but really flushed out the water in the grey tank. However the gray tanks is clogged again....The black tank remains clogged. I am guessing at this point I am going to have to call someone in to pump both tanks out. Any clue how much that will cost me?
thomasmnile
calamus wrote:
Dont EVER dump grease down your drains in your RV
Or any solid food waste from plates and cookware. If that debris doesn't flush out with draining the tank it stays there and stinks. :E
mhardin
I always leave my grey tank open until a day before needing to dump the black tank. After dumping the black, I dump the grey tank to flush everything on down the hose. Then, I leave the grey tank open until the next time.
Nunyadamn
If you are connected all the time, you can leave the grey tank valve open all the time (except maybe when it gets really cold - could freeze water in your line if not insulated).
Someone - please correct me if I am wrong.
2014 Jayco Jayflight 32BHDS
2015 Ford F250 Lariat 4x4 Crew Cab 6.7L Powerstroke
Vet_Man
Looking in the tank my by deceiving you, these tanks are quite shallow so they look full even when not.
2008 Itasca Sunrise 35A
2008 Honda CRV Toad
2016 Chev ZR1 Colorado Toad
"We Traveled To Alot Of Different Places While On Vacation, Until The wife Asked Directions"
myredracer
Accidental double post... 😞
myredracer
For a badly plugged up tank, try liquid Drano. Our owner's manual says to use it. Needs to be the version that does not attack metal. We had a badly plugged black tank last year and used it and the tank ended up looking like new inside. If you do use it, NEVER dump it into an on-site septic disposal system or you can do serious damage to it.
If your black tank is a problem, you may not be using enough water in the tank. You should put in 4-5 gallons after each dump just before you use it again. And use plenty of water each time you flush, especially with #2. Don't ever skimp on water thinking you can extend the time between dumps. You are asking to get plugged up by skimping on water.
On the grey tank, as said above, it may be due to grease. Avoid putting any grease into the grey tank.
We have a Valterra clear back flush elbow. It kinda works okay, but I find that the tank rinser is better. The elbow is the next best thing to a rinser though. I don't use it for back-flusing anymore now that we have a tank rinser. I always use the clear elbow to see whats coming out and if it is clear water or not.
A tank rinser for the black tank really helps. We have a factory installed one and I can get the bottom of the tank looking clean as a whistle. This one is a Tornado Rotary Tank Rinser. If you have an enclosed underbelly, it will be a challenge to get access. And if you do pull off the coroplast material, I would upgrade to Horst Miracle probes at the same time. The standard OEM button sensors are next to useless.
Bumpyroad
nomad297 wrote:
The Flush King is worthless unless you have a straight shot from it to your tank. If there are any fittings in the drain the flow from the hose becomes slack.
Bruce
sort of like trying to push a chain.
bumpy
nomad297
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
Tequila
I like 5 star happy camper. That stuff works great.
LakeN
The Flush King attaches to your sewer exit.....easy to use + highly recommended. all you need is an old hose to shoot water up thru FK into grey/black tank. this should flush your tanks. Has a clear fitting so u can see what is draining out.
wouldnt be without one! Once clear use proper chemicals!
'16 Winnebago Minnie Winnie 25B
'14 Ford Focus Titanium Toad with Blue Ox tow system
Oasisbob
Once you get it unclogged I suggest insfalling a sprinkler type tank rinser and flushing more often. I think they are called "Flush King" or something like that. Works great on both my tanks. I use to live in my fiver full time in a park and would flush every five days or so. Best of luck
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS:)
Bumpyroad
install a black tank sprayer and get that stuff moved to drain. if you have a permanent pyramid, use the hole cut for the sprayer and stick a pressure washer wand in there to blast everything.
bumpy
