Tell me your horror stories (Diesel)
ib516
Ok, so browsing through the thread about the 2011 Ford diesel left me in shock. Seems like there were many issues with the early builds of that engine. I know the Cummins and Duramax of that generation had their own issues (mostly emissions related?).
How are the newest gen Ford 6.7L diesels holding up (2015+)?
Are their similar stories for the Cummins and Duramax in the latest gen (2014+)? I know the Cummins has been 370hp/800tq for a while (in the 2500), have they worked out the kinks in that one? Are failures common? I only know one guy with a 2014 Ram 6.7L Cummins SRW 3500. He has had plenty of recalls and was losing coolant a while back, but I think that was the famous water pump issue. He has had no serious issues. His is a 370hp/800tq version with a 68RFE auto. But that's a sample of 1 which is pretty meaningless.
I went with a 6.4L Hemi last time I was shopping as it suited my needs better and frankly, I was scared away from diesels (all of them). At that time, my research told me they weren't worth the gamble. What I mean by that is their superior towing performance wasn't worth it to me when they could cost me tens of thousands to repair if they failed, and they were all (my opinion) having reliability issues in the 2011 to 2013 time period. I thought they were mostly pesky ones to do with emissions, but I'm just not into check engine lights on new trucks.
Are the diesels getting better? Should I put them back on my shopping list for my next new truck?
I'll likely be towing under 10k GVW, and it'll likely be a TT around 30'. I do want to log some miles though, and that will include some long distance touring (cross Country type).
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
149 REPLIES 149
rhagfo
BB_TX wrote:
ShinerBock wrote:
BB_TX wrote:
Diesel horror story? Diesel running 60-70 cents more per gallon than gasoline.
It would still have the same cost per mile as a gas engine at 60-70 cents more.
Cost per mile formula
(1 mile / miles per gallon) x fuel cost per gallon = cost per mile
Example:
Ram 6.4 Hemi
(1 mile/12 mpg) x $2.50 per gallon= $.21 cost per mile
Ram 6.7L Cummins
(1 mile/15.5 mpg) x $3.20 per gallon = $.21 cost per mile
DEF adds $.001 per mile
Yeah, but now it is not paying anything toward that $8,000 diesel engine investment.
Around here the difference is only about $0.15 to $0.20 so payback will happen. Besides the $8,000 is an investment in smother towing!
kw_00
The bullet proof 6.0 does very well in my experience. I have a few friends that have done the upgrade and achieve longevity. So I consider that expense money well spent if you plan keeping the 6.0. Now if you would ask me about diesels at work then I donโ€™t care for them, and yes we have lots of issues. However to be fair, the 6.7 Ford has done well over the years in service. Not so much with the 6.0 non bulletproof or the 6.4. If I were to own another diesel I would personally go with the Cummins or the duramax. But since I donโ€™t pull more then 10k and not all the time, I canโ€™t justify the ownership of one especially since thereโ€™s potential expensive issues with them. I know some donโ€™t believe that last statement but Iโ€™m honest enough to say when they break they break and are expensive...... now if we look at the reason why they break sometimes is because of ownership mods or just poor maintenance by the owner. So a lot of times on YouTube and on the net, I watch or read the dramatic horror stories only to realize you always canโ€™t blame the truck but the owner who tunes it way up and role coal.....
A truck, a camper, a few toys, but most importantly a wonderful family.
phillyg
I just put nearly $10k I my 2005,6.0 Ford. After thoroughly researching newer Fords, it seems they all have problems, even to the point that previous naysayers about the "notoriously bad" 6.0, have changed their tune. Apparently, many of the recent 6.7 motors have been repaired on warranty, and if one has to do it on their dime, it's way more expensive to repair than older motors. Once a 6.0 has been "bulletproofed," it supposedly will run another 200,000 miles with no problems. So, I kept mine.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
kw_00
Ok disclaimer, I donโ€™t own a diesel, so my family experience since diesels are mentioned.
Moms got a 2011 Ram 3500 HD has about 150k I think or more. Had a dpf filter issue a few years ago and was stuck at 15 mph pulling a camper out west. Dealer had to either replace or clean the filter, I donโ€™t recall. Turbo failure last year, and new turbo installed, otherwise a great truck.
ppine
2002 7.3 diesel is the best engine I have ever had after 170 k miles.
In Nevada, gas and diesel cost bout the same.
Best mileage is 23.8 mpg with a one ton.
BB_TX
Example:
Ram 6.4 Hemi
Ram 6.7L Cummins
73guna
Ive never had any horror stories but if I did Id forget about them once I started pulling that 7% mountain grade and listening to that turbo whistle!
Purr diesel purr!
2007 Chevy Silverado Crewcab Duramax.
2016 Wildwood 31qbts.
Bionic_Man
I had to replace injectors on my 2003 CTD in 2011, around 115,000 miles on the clock. I think that was around $3k, but I don't really remember what I paid. Also needed ball joints the year before.
This year on my 2012 CTD, I had to do a new fuel pump and new power steering pump. Those two, plus the scheduled EGR valve cleaning was about $3000.
I am still happy with my truck, and if I were in the market today, I would buy another.
And I am 100% convinced that there are many on this forum that will claim 100% reliability on their trucks regardless of if that is actually the case or not. If someone has their brand in their user name, or posts links to their manufacture of choice's marketing material while singing their praises, I would take their word with a grain of salt.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
SidecarFlip
ford truck guy wrote:
my 2015 6.7 has been a fantastic motor. It is strong, quiet, and pulls like a dream...
But I am sure that Turtle will be along shortly with a bunch of cut and paste links as to why I am wrong...
Turtles are good to eat so long as you dip them in boiling water and peel off the shell before you make turtle soup.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Lantley
I think your researching a problem that doesn't exist. While I'm not naive enough to believe diesels are now perfect, there are very few problems at this point.
Reliability across all brands is very good.
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
DutchmenSport
None from me. 2014 Chevy 3500 Dually Duramax 6.6 L Diesel, long bed, crew cab.
Absolutely none.
IdaD
I wouldn't get anything with a CP4 pump in it, so that eliminates the Powerstroke and Duramax up until the 2017 (I think) models. I'd not hesitate to get the Cummins or current Duramax. The towing performance blows gas trucks away, and even not towing it's just really nice having all that torque off idle. Only issue with my 2015 is a failed water pump which is a known problem.
2015 Cummins Ram 4wd CC/SB
Learjet
23,500 miles on my first Diesel...nothing but similes and POWER !!
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
ShinerBock
Example:
Ram 6.4 Hemi
Ram 6.7L Cummins
2014 Ram 2500 6.7L CTD
2016 BMW 2.0L diesel (work and back car)
2023 Jeep Wrangler Rubicon 3.0L Ecodiesel
Highland Ridge Silverstar 378RBS
