Aug-20-2013 08:16 AM
Aug-20-2013 09:10 PM
Aug-20-2013 06:56 PM
Reese Dual Cam Straight Line HP Sway Control
Aug-20-2013 01:03 PM
Aug-20-2013 10:28 AM
Aug-20-2013 10:26 AM
katoom400 wrote:If it was me, I'd be make a scale drawing on paper before i invested money in grading, retaining walls, and concrete. Look at the picture, raise the front wheels on your SUV until they are perfectly level with the rear wheels and the rear fender is on the pavement. Now consider that overhang on the RV is about 5 times more than the overhang on the SUV and you just compounded the problem. Looking at the photo, my eye says your money is going to be wasted. Like I said, a scale drawing will tell you - which is time well spent before the money is not so well spent.
I don't think the slope is that drastic, also the Outback 250rs is taller (has more ground clearance) than most TT's we have looked at.
Aug-20-2013 10:07 AM
Aug-20-2013 09:51 AM
93Cobra2771 wrote:
Some wood under the wheels isn't going to hurt anything. However, don't rely SOLELY on the xchocks to hold it in place. Believe it or not, they aren't made to keep the trailer from rolling, they are for stabilizing and stopping rocking when you are inside.
With that much slope, some good ground based chocks along with your xchocks are a must. I don't think I would put the slides out with that much slope, as I'm not sure if they are designed to open like that.
Tighten the xchocks as tight as you can get them.
Aug-20-2013 09:40 AM
Aug-20-2013 09:37 AM
Aug-20-2013 09:02 AM
Aug-20-2013 08:52 AM
