The only real SRW “One Ton” that isn’t really a 3/4 ton
burningman
Just for the heck of it, here is the only real one-ton single rear wheel pickup ever made that is NOT just a 3/4 ton with a different sticker on it.
The 1973 to 1979 Ford F-350 Super Camper Special. Not just the common “Camper Special” but the Super Camper Special.
These things had a 5355 pound payload. Way more than any new SRW pickup.
Notice the set-back rear axle. They had a special bed to fit. They were made to haul big campers, and that set-back rear axle also let the front end take more of the weight.
No camper center of gravity issues at all.
They came with 12.00 x 16.5 rear tires.
They came with frame tie down points, camper power connectors, trans coolers, and a spare tire under a big door on the passenger side of the bed.
No crawling under.
These were the best single rear wheel camper haulers ever, and the only single rear wheel one-ton pickup that wasn’t just an up-rated 3/4 ton.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
35 REPLIES 35
deserteagle56
StirCrazy wrote:
but man were they ugly compared to the normal truck of that year, and they sucked on fuel like a pig at the slop trough. as much as I am a ford guy, I would just keep walking by that.
On a scale of 1 to 10, in my book the importance of "looks" would rate about 15.
Stick a Cummins under the hood and fuel mileage improves dramatically. So does the ability to climb a hill without shifting.
1996 Bigfoot 2500 9.5 on a 2004 Dodge/Cummins dually
StirCrazy
Navigator
Navigator
No crawling under.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
rhagfo
I remember those, and it was another VHS vs Beta challenge. The other manufacturers should have come out with the same design for choice. Instead they started pushing short beds!
Geo_Boy
Don’t let Specta see this!:B
joerg68
Nomad III
Nomad III
Very nice automobile. But I doubt many modern campers will fit between those far aft wheel wells. The ones I had all were designed for the more common, forward position of the axle and got considerably wider in the back.
2014 Ford F350 XLT 6.2 SCLB + 2017 Northstar Arrow
gbopp
:C :C
