โOct-29-2017 01:52 AM
โNov-06-2017 07:06 AM
โNov-05-2017 12:27 PM
โOct-29-2017 03:43 PM
โOct-29-2017 02:27 PM
โOct-29-2017 01:09 PM
Vinsil wrote:
Yes, but you still have a failed seal and water will still get in.Going down the road, your camper gets pressurized and will actually pull water into the easiest path, and a failed window seal is exactly that. So while your gutter idea works for stationary use, going down the road will still show it leaking.
Like it was said, pull the window and use the tape. It's not hard to do and it's the only proper way to fix the leak.
โOct-29-2017 12:39 PM
โOct-29-2017 11:42 AM
Kayteg1 wrote:
The awning mounting trim sure is big suspect.
I had that on my Lance, what coming from dry climate had relatively low dryrot, yet the beam above slide was completely rotten. Good roof.
Doing the repair I figured out the manufacturer never put a seal on awning trim and water penetrated via screw holes.
I triple caulk the trim on the top.
โOct-29-2017 11:23 AM
โOct-29-2017 11:04 AM
โOct-29-2017 10:07 AM
โOct-29-2017 09:21 AM
โOct-29-2017 08:00 AM
โOct-29-2017 07:27 AM
