Oct-08-2017 03:18 PM
Oct-10-2017 03:06 PM
Oct-10-2017 12:41 PM
Kayteg1 wrote:Reddog1 wrote:
If you have the factory tires and wheels, I suggest you use the PSI as stated in your trucks user manual or the door decal.
If you have aftermarket tires, of a different size than factory, use the tire manufactures recommendation.
I think it is worth noting, you are driving a truck, not the family car. It will ride differently with and without a TC.
Wayne
Door decal on 1-ton trucks shows the pressure recommended for 1-ton load.
When you load 3 tons, this is going to change.
Oct-10-2017 09:42 AM
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Oct-10-2017 08:39 AM
Wayne
Oct-10-2017 06:56 AM
Oct-09-2017 11:11 PM
Oct-09-2017 02:29 PM
hedgehopper wrote:
Recently, we have been running 80 psi all around with our10-2 Northern Lite on our Dodge dually diesel. This is more than the recommended pressures from the tire loading charts. However, I like the increased stability the higher pressures provide. And higher pressures provide better fuel economy. The tires will probably wear more in the center of the tread. And yes, the ride is a little rougher. But we are willing to live with that.
Oct-09-2017 02:24 PM
Oct-09-2017 11:39 AM
Oct-09-2017 10:39 AM
Toad: 91 Zuke
Oct-09-2017 08:33 AM
Oct-09-2017 08:19 AM
Oct-09-2017 07:02 AM
Oct-09-2017 06:58 AM
