Aug-07-2017 12:17 PM
Aug-10-2017 06:03 AM
Aug-10-2017 05:43 AM
Aug-10-2017 05:41 AM
Aug-10-2017 04:46 AM
Aug-09-2017 09:47 PM
Aug-09-2017 09:33 PM
Grit dog wrote:
Yes you can air up to what the tire says.
Your little camper will be about 2000lbs if your lucky. Get any flavor of load range E tires so you can stiffen up the back. Will be a much better ride in your half ton. And you can air back down to 35psi when you don't have the camper.
Aug-09-2017 09:16 PM
OK so now Im confused. Can I up the back to 51 PSI or not? Im not an expert. I was going to but after reading the last post, Im not so sure. Thank you.
Aug-09-2017 08:57 PM
robertjp wrote:jadatis wrote:
Your tires are most likely Standard load P-tires, and on those they only give maximum allowed cold pressure.
The maximum load of tire can be carried up to 99m/h AT 35 psi , wich is standard reference-pressure for P-tires SL. So if you drive only below 99m/h you may use the 35 psi.
The space between 35psi and 51 psi is used to highen up the referce-pressure ( further AT-pressure) for higher speed then 99m/h with a system depending on speedcode of tire. Also for alighnment camber angle above 2 degr.
LT tires give on sidewall the AT-pressure , and in earlyer days higher was allowed and even adviced upto 10 psi extra, but nowadays the tiremakers dont allow it anymore, and so the AT-pressure is the maximum allowed cold pressure.
So tiremakers allow for SL P-tires a higher pressure then AT, and if you use it to cover some higher load on tire then maximum load, they cant prove you did it for that higher load then max ,that they dont allow, but mother nature will be happy with it.
To high pressure gives that less deflection of tire, that things go bumping, so to high is not bad for the tire, but bad for your kidneys and teeth-fillings.
Aug-09-2017 07:34 PM
jimh425 wrote:
I'd probably look at load inflation charts for those tires, but the tires won't be worse for wear at max pressure. The handling will be different, and you could get some abnormal tire wear especially when unloaded.
The tire ratings in the door are designed to give you a guide for what is the pressure you should run at sticker max GVWR.
Aug-09-2017 07:31 PM
Aug-09-2017 03:02 PM
Aug-09-2017 01:26 PM
Aug-09-2017 01:07 PM
robertjp wrote:
Yes 2460 lbs max load on the tire rating. Im assuming this is in addition to the truck?
Aug-09-2017 11:44 AM
Aug-09-2017 10:26 AM
