Mar-12-2014 08:14 AM
Mar-25-2014 11:57 AM
Mar-20-2014 05:18 PM
Mar-18-2014 09:06 AM
whizbang wrote:
Sonofgun your present tires have a load rating of 2601# ON A PASSENGER CAR. On a truck, your tires are downgraded to about 91%, or 2366#.
"E" rated LT tires at 3600# will make your truck drive like a rock. Not good.
A better choice, and what I did with my F-150, is light truck "C" rated tires at 2535# --- better load capacity without sacrificing ride comfort.
Mar-18-2014 05:05 AM
Mar-17-2014 10:09 PM
Mar-17-2014 09:53 PM
Mar-17-2014 08:53 AM
Mar-16-2014 07:52 AM
Mar-14-2014 09:18 PM
Mar-13-2014 07:22 AM
Reddog1 wrote:
With all due respect, a load capacity of a given tire is what it is, the load capacity. All load range "E" tires do not have the same load capacity, in different sizes.
Mar-12-2014 09:24 PM
Mar-12-2014 08:51 PM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Mar-12-2014 08:03 PM
Mar-12-2014 07:47 PM
ah64id wrote:With all due respect, a load capacity of a given tire is what it is, the load capacity. All load range "E" tires do not have the same load capacity, in different sizes.Reddog1 wrote:
My suggestion is to ignore the "E" rating (load rating), and go by the load capacity. You can have an "E" rated tire in different tire sizes, and each will have a different load capacity, as I understand. The load capacity is on the tire, regardless of the tire size, the load capacity is the load capacity.
Wayne
E is the load rating, even if a LRD and LRE are rated for 3195lbs the LRE is a tougher tire and will almost always hold more air. More air means cooler rubber, more stability, and better war.
Load capacity is indeed important, but it's not too common for a LRD to have the same capacity as a LRE of the same size. It does happen, but not the norm.
Toad: 91 Zuke
