Tire recommendations for pick up truck for towing
Roger745
I have a 2018 Silverado 1500 LT that use to pull my TT. Looking for suggestions for quality tires for my truck. Not really interested in Chinese products.
Any thoughts are appreciated.
29 REPLIES 29
Grit_dog
Navigator
Navigator
valhalla360 wrote:
Cummins12V98 wrote:
Whatever you choose be sure it's a "D" or "E" load range.
Look up the axle rating then pick a "Load Index Rating" that meets or exceeds the axle rating.
Load E can have a variety of actual load ratings. The letter grades are an old system from the days when they added extra plys to the tire to make it stronger. The more plys the further into the alphabet the letter grade went.
Modern tires don't add plys. They change the steel in the tire without adding plys.
Load Index Rating gives you the actual capability in pounds.
And yet, any tire in an applicable size for any of the common rim sizes on that truck will have a Load Index that is somewhere between adequate at the very worst case and overkill. Most will be overkill.
valhalla360
Nomad III
Nomad III
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
riltri
Another Michelin fan but I went with the AGILIS CROSSCLIMATE. Really like them.
Blue Ridge Mtns - NC
Second_Chance
Both the Michelins and Coopers have given me very good service. LT load range E, of course. That said, this has been discussed hundreds of times on the forum if you use the search function.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Grit_dog
Navigator
Navigator
Add falken, Toyo and Nitto to the good list.
Ask a vague question, get vague answers.
Grit_dog
Navigator
Navigator
And Cooper, bfg, Firestone, Goodyear, Pro Comp, Mickeys and Hankooks are good tires tooโ€ฆ.
Point being, get some tires that are suited for your traction needs and make them D or E load if for no other reason, theyโ€™ll outlast the comparable light duty tires by more than the extra $20 a tire that they cost.
Dadoffourgirls
I have Pirelli Scorpoion All Terrain Plus and Continental Terrain Contact HT that I run Winter and Summer on my Express van. Like them both.
Dad of Four Girls
Wife
Employee of GM, all opinions are my own!
2017 Express Ext 3500 (Code named "BIGGER ED" by daughters)
2011 Jayco Jayflight G2 32BHDS
valhalla360
Nomad III
Nomad III
Usually buy the off brands. Always have gotten good mileage out (40-50k miles) of them and never had a blow out or other issue.
Just make sure the load rating is sufficient to meet or exceed the axle ratings.
Then you have the question of tread type (highway vs off road) but that depends greatly on how you intend to use it.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
IdaD
Falken Wildpeak AT3W. Best tire I've ever run on a truck, and they hold up to an HD diesel. I think they'd be great on a half ton too.
2015 Cummins Ram 4wd CC/SB
pitch
I,ve run Cooper AT3. Had them one set on my previous truck and two sets on this one.
First two sets were D rated really liked them. Latest set is "e" just because they were in stock. These also perform like a champ,just a bit stiffer.
I have no argument with Michelins, But they are like John Deere or Kubota,a superior product,but not by enough to rate the premium that is charged.
phillyg
I've been disappointed every time I strayed from Michelin.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
bob213
X3 for Defenders
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
larry_barnhart
Defenders have been good for what we do.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
guidry
I have been running Michelin Defenders for years. I won't have anything else; I've tried them all. A little more expensive but after trying the others, I always came back to Michelins.
