โJul-02-2014 12:15 PM
โJul-04-2014 02:10 PM
MM49 wrote:Lowsuv wrote:With all of you accumulated knowlage not one OEM tire manfacture has supported your position. Every OEM ST manufacture has reccomended the use of ST tires. Maybe is a west coast thing?
After all of this name calling has not anybody understood that :
The Goodyear Cargo G26 225/70R 15 load range D is the most tire we can buy that fits our 15 inch wheels ?
The data is there .
To put it bluntly , do not be fooled by the recent posters who offer no valid solutions better than the G26 .
They do not show evidence supporting their position .
Instead they resort to degrading the messenger .
These 3 are robbing the rest of us of the best solution by simply clouding the issue with their personal attacks .
Not one of them would last 10 minutes in a face to face discussion that required a working knowledge of these tires .
View the posts by JJ , MM , and FE and decide for yourself if any of these fellows do any in depth analysis to reach a logical conclusion .
Compare their knowledge to LowSuv , Huntindog , GMWPhotos , PartyMarty , Sprinklerman , and a few others for yourself .
The latter group just plain has a better working knowledge of the tire issue than JJ, MM , and FE .
Hence the name calling by JJ , MM, and FE .
MM49
โJul-04-2014 02:06 PM
FastEagle wrote:legolas wrote:bob213 wrote:
Keep in mind that Lowsuv never misses an opportunity to bad mouth Maxxis tires. He's correct when he recommends LT tires if your trailer can handle the larger size. If you are stuck in the 14" range, your best choices are Maxxis or Kumho 857. In a 15" tire you are again limited and Maxxis would be my first choice. in a 16" you have a wide range of LT tires that would serve you well.
I hate to get in to this....knowing the angst of it ......however, are there no 15" LT tires that can go on a TT?
Not often.
FE
โJul-04-2014 01:55 PM
Lowsuv wrote:With all of your accumulated knowlage not one OEM tire manfacture has supported your position. Every OEM ST manufacture has reccomended the use of ST tires. Maybe is a west coast thing?
The data is there .
โJul-04-2014 01:49 PM
โJul-04-2014 01:32 PM
JIMNLIN wrote:I hate to get in to this....knowing the angst of it ......however, are there no 15" LT tires that can go on a TT?
Sure. We have a few sizes and a couple of load ranges in a 15" LT and all position cargo/van/trailer tires.
Depending on room in the wheel well and proper wheel pressure/wheel width requirements the Goodyear Wrangler HT in a LT235/75-15 C (50 psi) at 1980 lb capacity. Most LT tire makers carry this size.
And a Wrangler HT in a LT215/75-15 D (65 psi) at 2090 lbs capacity.
Maxxis LT U-168 are a commercial grade tire with several 15" sizes and have became popular with all types of trailer owners.
Vanco 2 from Continental another popular tire for trailer users has several 15" sizes and load capacities.
I see the Yokohama RY215 in a 700R 15 D at 2040 lbs capacity is popular on some of the other RV websites.
Do your home work on the numbers.
โJul-04-2014 01:03 PM
โJul-04-2014 10:49 AM
โJul-04-2014 10:02 AM
โJul-04-2014 09:51 AM
โJul-04-2014 09:28 AM
โJul-04-2014 08:54 AM
โJul-04-2014 08:08 AM
โJul-04-2014 07:35 AM
MM49 wrote:Lowsuv wrote:It would help if LowSuv was honest. He keeps on recommending LT tires that are rated at lower weight ranges for equivalent sizes and tires that don't fit our rims or trailer wheel openings. The increased leverage of using LT tires that are not designed for trailer usage is potentially damaging to the trailers suspensions and frames. Lt Tires don't meet the performance standards of ST tires.
Keep in mind that it is LowSuv's intention to help the civilians on this forum with their tire issues .
LowSuv includes in his posts the logical evidence that indicate that Maxxis is a provider of lower grade tires .
Other motorheads on his forum who have decades of experience upgrading their tires on their hotrods , sportscars , pickups , and other trailers have a good understanding of how a real upgrade in tires is possible for little expense at changeover time .
LowSuv does not enter into personal attacks on this forum .
Maxxis ST tires are most often supported on this forum by references , such as " I really like them " , or " my tire guy ( whoever that is ) says you cannot use LT tires on a trailer ".
My whole intention is to allow other RV forum members to make a real upgrade that will eliminate / mitigate future ST tire failures going forward .
The evidence supports the position that Maxxis tires are not a better brand than other ST tires .
Those suggestions that just replacing OEM tires with a maxxis tire of the same load weight rating are just plain wrong . There is no gain to be made by that Maxxis replacement .
LowSuv repeatedly gives reasons why for 15 inch tires the 225/70R15 load range D Goodyear Cargo G26 is the clear first choice .
LowSuv repeatedly gives reasons why for 14 inch tires the 205R14 Kumho 857 load range D is the clear first choice .
A search through " view posts " for LowSuv will show that his suggestions are supported by logical evidence and have been consistent for a long time .
As a motorhead LowSuv made his first tire upgrade in 1964 on his 1955 BelAir by going to 720x15 tires instead of the 670x15 tires that came stock .
LowSuv has been upgrading his tires ever since .
I encourage upgrading tires at replacement time .
Changing brands to Maxxis does not accomplish this .
MM49
โJul-04-2014 07:20 AM
MM49 wrote:Lowsuv wrote:A new first, every single statment is wrong.
MM49 has resorted to character assassination because the facts do not support his position .
Using the " view posts " feature one can ascertain that LowSuv recommends using the Gargo G26 225/70R15 in place of the ST 225/75R15 tire .
LowSuv has given the dimensions of that G26 and it is available just a few posts above by PartyMarty .
The G26 225/70 will also fit most trailers that came standard with the ST205/75R15 but it is up to the user to check that .
The G26 225/70R15 fits our stock rims .
I have said repeatedly ( view posts ) that if you are going up a size that you need to measure .
I installed Continental Vanco2 215/70R15 at changeover time instead of my stock ST205/75R15 with no measurement issues .
Increased Leverage ?
Really ?
How many threads are there about damaged trailer suspensions and frames ?
How many threads are there about LT Tires causing damage to trailer suspensions and frames ?
The biggest problem we are addressing is that ST tires are overrated in sidewall weight capacity .
Using the " view posts " feature it is possible to find the exact comparisons of tires made by the same manufacturer that shows that the ST standard allows a 15 % weaker / cheaper tire to be used .
The post above by PartyMarty is one of those comparisons .
LT tires Exceed the performance standards of ST tires .
That has been proven many times on this forum .
MM49
โJul-04-2014 07:15 AM
Really ?
