โMar-15-2014 02:25 PM
โApr-02-2014 09:02 AM
โMar-18-2014 05:24 AM
โMar-18-2014 05:00 AM
โMar-17-2014 02:12 PM
crittersitter wrote:
Just bought a 2004 Ford Expedition that will be our tow vehicle. Needs new tires. What would be a good choice? Will be towing a 5000lb travel trailer 2000 miles next month but then will be towing only short distances a few times a year. I assume a LT rather than P tire. Does it have to be E rated? Don't want to spend top dollar but enough for a decent 50k mile safe tire. Suggestions?? Thanks!
โMar-17-2014 01:53 PM
โMar-17-2014 01:40 PM
NCMODELA wrote:
I am 200lbs under my gvwr and 950 lbs under my gcwr. I had it weighed on cat scales. I try to pack light to keep it that way. I thought if the tires were softer on the side wall like P's are they had a little more bounce to them unlike the lt's which were stiff to up and down movements. I do know that the rear shocks are getting a little older so that may be it too. The TT is 5680 dry.
โMar-17-2014 11:43 AM
โMar-17-2014 08:55 AM
NCMODELA wrote:
So, I have a question just like the op, I have a 03 yukon xl, 6100 TT loaded. I am pushing my capacities but only tow 3 or 4 times a year at max 200 miles each way. I need new tires on my truck, I was going to go with the hankook ht LT E tires. The yukon has a slight pourposing effect driving down the road but it is not awful. It has a little sway but not awful. I was hoping the E rated tires would take this out but would XL's do it too?
thanks
Bill
โMar-17-2014 08:16 AM
โMar-17-2014 08:08 AM
โMar-17-2014 06:32 AM
โMar-17-2014 05:41 AM
CKNSLS wrote:
I think we forget that most half-ton trucks on the market come with "P" rated tires when new. And those tires must handle the tow rating as supplied by the manufacturer.
โMar-17-2014 05:32 AM
lumpy790 wrote:
getting 6 new tires this week and the tire shop does a ton of dually set ups on trucks, box vans (likeI have) and people haulers. They suggested Uniroyal tires. Opinions on them?
โMar-16-2014 08:53 PM
Desert Captain wrote:CKNSLS wrote:Desert Captain wrote:
I continue to be amazed by the myth that all LT tires ride rough. :h If you buy the right tires and properly air them up the ride is smooth and quiet while providing superior (vs P's), performance.
One of the keys in selecting the right tire is get a street tread. I recommend the Michelin LTX M/S 2's. I put them on my truck and the improvement in ride and handling was awesome. I just got a set installed on our C (thanks to the recall of the old M/S's) and they are so much smoother two or three of the persistent rattles that plague most C's disappeared. If you are towing anything, get rid of the P's as that is not what they were designed to do.
As Always.... Opinions and YMMV. :C
If you air them up to maximum pressure they will ride very rough. There is NO ADVANTAGE TO BUYING LT TIRES AND THEN ONLY FILLING THEM TO 2/3rd CAPACITY. There goes your load ratings out the window....
Ridiculous! :S You air tires, any tires, to the proper pressure based upon the load they are carrying. If you are towing, air them up to that load, if not air them to the reduced load they are actually carrying. The advantage of LT tires is the heavier construction/higher plys which do not vanish as the load and appropriate pressure is dialed in.
Airing an LT to its max rating does NOT necessarily dictate a rough ride. A street tread, aired to the proper pressure based upon the load it carries will give a smooth and quiet ride. If that is not what you are getting it is time to check your suspension, shocks etc... the tires are not the problem.
:R
