Sep-01-2023 02:07 AM
Sep-01-2023 05:12 PM
Sep-01-2023 01:49 PM
Sep-01-2023 01:00 PM
QCMan wrote:
Inflating to max load will cover anything you put in it but loading to the max sidewall pressure when not needed will result in a lot of bouncing being that most trailers do not have shocks to stop that.
Sep-01-2023 11:54 AM
Sep-01-2023 08:02 AM
QCMan wrote:
Unless they say "always inflate to xx psi" on the sidewall then go to the tire manufacturers site and find their inflation chart for the tires. 8000 max divided by four is 2000 pounds on each tire so that is the load that you need the psi for. If it does say "inflate to xx psi" on the sidewall then that is the only number you need.
Sep-01-2023 07:04 AM
Sep-01-2023 06:38 AM
Sep-01-2023 05:36 AM
Sep-01-2023 05:21 AM
Sep-01-2023 05:13 AM
