Toilet water flow very slow
tuna_fisher
At the end of our last trip on the way home I noticed that the water at the toilet was about 1/3 flow, like it was plugged. Well I just loaded the camper prepping to leave and noticed it again, yes I forgot to look into it.The flow everywhere else is fine.How would I go about checking the line for a plug? Would blowing air thru it be possible? It still works but very slow. I have a Lance 185S Squire Lite. Thanks
2001 GMC DM, 1995 Lance Lite, @005 Eclipse Toyhauler, Toy's!;)
18 REPLIES 18
dadwolf2
tuna fisher wrote:
My wifes purse is heavier.
If your wife's purse is anything like my wife's...try a different comparison! :W
2005 Dodge Ram 2500 CTD,4X4,NV5600
2014 Adventurer 86FB
K_Mac
Glad to hear everything came out all rite,,I hate when my plumbing get's "backed-up". Sorry I couldn't resist 🙂
tuna_fisher
Toilets back in and the water flow is working great again. Just a little hard water deposit, came right out. All's good in toilet world again....
pjay9
Trailgranny50...remove the flow restrictor from the hose and shower head, if can't remove with pointy tool then drill a hole in it and step up the size until you get the flow you want. They hide those restrictors in many places, sometimes at the hose ends and then in the shower hand head near the connecdtion point, may even be a screen that is plugged with goop/sand etc, clean it see if that fixes your issues...the taps have these too at the end call aerators with screens and restrictors.Hope this helps!
Don't be timid to remove them, just take note of order and direction to put it back...don't need to put all of it back either I usually just leave the screen part and clean it once a year.
2005 Lance 1161, 2004 Dodge CTD 3500 Dually 19.5's Stabiloads Roadmaster Sway, 2009 20' Raider 185 Pro Fish 90hp & 9.9 Yamaha vintage Penn elec.downriggers EZLoad roller trailer
tuna_fisher
Well I removed the toilet today and found my problem to be a calcium deposit plugging the valve, poked the hole with a peice of tie wire and it's working, now just waiting for a new seal. Great time to clorox the bathroom with the toilet removed. Sure was suprised how light those plastic toilets are.My wifes purse is heavier.
trailgranny50
Had that problem in the past and it was the valve where the water came into the bowl. Like someone else said just a small plastic piece, cheap and fairly easy to replace. Worked wonders. And like yet another poster, our newly installed stool has the reverse issue. Wish the shower head had that much pressure! LOL
2004 Chevy 3500 Duramax all stock
1990 950 Shadow Cruiser Hard side multiple add-ons
Ancient Valco 10'x5' John boat
2011 Toyota FJ Cruiser Trail Team
One-eyed Trail Horse and one horse trailer
Rocky, Annie, Muffie traveling Fur Babies
JoeChiOhki
If your unit is a Thetford Aqua magic, the water line and connection is hidden in the center of the back of unit.
My Blog - The Journey of the Redneck Express
CB
Channel 17
Redneck Express
'1992 Dodge W-250 "Dually" Power Wagon - Club Cab Long Bed 4x4 V8 5.9L gashog w/4.10 Geared axles
'1974 KIT Kamper 1106 - 11' Slide-in
'2006 Heartland BigHorn 3400RL
tuna_fisher
Well it's been about 4 months and a few trips and still not fixed, I do have good flow at the incoming water line so I'm going to pull the toilet in the next week and see what I come up with. I'll report my findings and won't leave you hanging. As you can tell I'm not in a real rush, want to take care now while I have time between trips. Just got back from a week at Jalama Beach under perfect conditions so I'm rested and ready to go...
jmckelvy
tuna fisher wrote:
Did that and got a pretty good look. Don't think it will be to hard. Will tackle when we get back. Thanks everyone for your suggestions. I hope you won't hear from me about this problem again....
Please post what the problem turns out to be and the fix. Don't leave us hanging.:)
06 RAM 3500,Dually,CTD,Auto(ATS Stage 1),QC,4X4,PacBrake,Spyntec Freespin Hubs,60 Gal Titan Tank,EFI Live, Line-X,Torklifts and SuperHitch,Fastguns
2013 Arctic Fox 990, 275 Watts Solar, 2 Grp 31 AGMs
US Navy 1964-1968, 2-Tour Vietnam Vet
tuna_fisher
Vet_Man
Maybe a mirror would help to look behind the toilet, and see if it has a fitting you could remove. If not removing the toilet may be your only choice.
2008 Itasca Sunrise 35A
2008 Honda CRV Toad
2016 Chev ZR1 Colorado Toad
"We Traveled To Alot Of Different Places While On Vacation, Until The wife Asked Directions"
tuna_fisher
You know you guys lost me with half these suggestions.I have no line visible coming into the toilet like the house to take off to check flow.The incoming water is from a little white thing that's on the inside rim of the toilet, so no line to disconnect.If my other water things work great and the toilet is last in line how could it plug and others good? I'll go dig thru my paper work and see what I can find on the toilet, thanks for all your reply's.
I take that back, there is a water line in the back,can't see it but feel it, feels like pex. Don't know how I can get to it, seeing as it'e only about4" off the wall and tight to the back of toilet. It comes straight up from the floor area, not out the wall like home. I'm replaceing my WH when I get back from this 5 day trip, maybe I can see more when I pull the water heater. I'm talking the other end of the water supply line.Couldn't find any paper work on the toilet, suprised as I have for everything else.
Old-Biscuit
Typically a problem with water flow to an RV toilet is the toilet water valve plugging up.
Unfortunately they usually are not serviceable cause they are a sealed plastic assembly.......replace.
AnEv942
Wow, I wish ours was at 1/3 flow, also wish it had a stop valve, Id throttle it back till it was at 1/3 flow.
But our toilet is plumbed direct and rigid PEX line, if there was what I thought a problem in flow (too little) it would be in the toilet valve itself. Id pull line to toilet-have someone turn pump on for a second (wet bath) to see if line or toilet?
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
