Toilet
earnesttee
Having problems with toilet,water still seeps in after flush?Bowl ran over to day did not catch the problem till it happen thanks for any answers newby learning
6 REPLIES 6
campigloo
Yep, sounds like a pressure problem, at least the simplest place to start.
NanciL
harold1946 wrote:
Too much water pressure can give the same symptom. It does not allow the valve to function properly.
I replaced one valve and still had the same problem. I called Dometic and they said to shut off the shore water supply and use the pump, see if the valve works properly. He said if it did to purchase a high volum water pressure regulator that limits it to 50 psi. Problem solved. I now have a spare valve.
Wow, that is interesting. Thanks a lot for posting it.
I hope I didn't jump the gun on my suggestion above.
Jack L
Jack & Nanci
harold1946
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
NanciL
Get the model number of the toilet and then buy and replace the valve.
It is a simple and inexpensive job if you do it yourself
Jack L
Jack & Nanci
azrving
Old-Biscuit
Time for a new water supply valve or assembly depending on which toilet.
Pretty much 'non-serviceable'.........R&R (remove/replace) as most stuff any more.
