Tongue weight
4x4ord
I want to pick up a piece of equipment about 150 miles from here and tow it home. I plan on towing it with my Super Duty. My guess is that I have exceeded this weight on my hitch in the past but I don't want to drive 150 miles only to find out the factory hitch can't handle the 2200 lbs that will be put on it. Anybody have experience with how much these factory hitches can handle?
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
45 REPLIES 45
4x4ord
mkirsch wrote:
No doubt it towed just fine. It's an ideal trailer. Tongue weight is close to 20%. It is very long with the wheels set far back. There is very little frontal area, and it is aerodynamic to boot.
The tongue weight was within the payload capacity for your truck so no doubt the tires and suspension could hold it up. You had plenty of power for the weight, especially considering how little frontal area it had.
Really about your only concern was that receiver. Nobody here would know what the design limits of that receiver are, just the factory ratings. A few farmers threw caution to the wind and towed similar weights, and it worked out for them. At that point it's up to you. Glad it worked out.
You would actually be surprised at the frontal area of the thing. There is a lot of surface area to catch wind so it pulled heavier than a much heavier fifth wheel RV does. In fact going up some minor hills on the highway it would take everything my truck had to maintain 60 mph.
B&W Companion
4x4ord
DaveF-250SD wrote:
Glad you were able to safely move it to your property. Which part of it is 13 feet wide? The wheels don't look like they are spaced out that distance across. I guess on a four lane road it would not be much of an issue with width, but on a two lane road the road would definitely have to be closed to all traffic in the opposite direction for the duration of your time on it.
The track width is 13' 4" so it was a little wider than the lane. I ran the left hand wheel right down the center line on the two lane highways. There is a flashing light right above the wheel which helps keep it visible. Here's another picture but it seems impossible to get an idea of the size of this thing from a picture. This is from Farm King's website:
B&W Companion
DaveF-250SD
2004 F-250 XL Super Cab short bed 4x4 V-10/4R100
1977 Chevrolet Scottsdale C-20 Trailering Special 454/TH400
mkirsch
Nomad II
Nomad II
4x4ord
Cummins12V98 wrote:
That's AWESOME ^^^^^^^^^^
It is. The pictures don't do it justice; the thing is huge. It is capable of emptying a semi load of grain in 3 minutes. It pulled very nice down the four lane at between 65 and 70 mph.
B&W Companion
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
4x4ord
B&W Companion
Fordlover
4x4ord wrote:
transamz9 wrote:
4x4ord wrote:
RoyJ wrote:
4x4ord wrote:
Permits and escort vehicles won't be necessary. I realize the sticker is going to have a number on it, I'm more interested in how much weight the hitch can take.
You sure about that? Or is this all off road?
At least here in BC, the legal limit is 53' length and 8.5' width just like any of the States.
Have you planned out the entire trip path to make sure all corners are negotiable? That is one BIG load!
Also, you may want a HD anti-sway setup. If it's a big box, 85' would create a ton of sway for a bumper pull.
In Alberta farmers are permitted to move their equipment down the roads. Apparently it pulls very nice down the road. What it is, is a big grain auger.
It might be different there but here you are limited to so many miles on farm tags.
I can check that out but I am quite sure our farm plate is province wide.
Here's a link to a picture of the thing.
Please post a pic of that thing hooked up to your truck.
2016 Skyline Layton Javelin 285BH
2018 F-250 Lariat Crew 6.2 Gas 4x4 FX4 4.30 Gear
2007 Infiniti G35 Sport 6 speed daily driver
Retired 2002 Ford Explorer 4.6 V8 4x4
Sold 2007 Crossroads Sunset Trail ST19CK
4x4ord
Just to update. A friend of mine ended up buying this same piece of equipment and towed it 550 km behind his 2004 srw Chevy with a factory 2 inch receiver hitch. He said it handled it just fine. I'm making the trip today.
B&W Companion
Cummins12V98
Sport45 wrote:
Cummins12V98 wrote:
Ya just don't want to end up looking like this guy that had just a bit too much hitch weight!
I'm not sure who wins the prize here. Is it the guy who jackknifed, or the driver who took the picture?
5 MPH I think I was safe. Maybe not.
The_Mad_Norsky
Sport45: good point. I do hope it was the rear seat passenger in a crew cab type pickup who snapped the photo though.
The Mad Norsky, Doll, Logan and Rocky
2014 Ram 3500 w/ Cummins/Aisin
2019 Northern Lite 10-2 EX CD LE Wet Bath
RV'ing since 1991
I took the road less traveled .....Now I'm Lost!
Sport45
’19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
4x4ord
The Mad Norsky wrote:
There is one other option.
Just use a tractor to pull it to where ever. No worries about hitch weight.
Shoot, these modern tractors would be heaven for me to use. LOL, we had the old Case 930's on our farm, add on cab, no A/C, no ear protection. No turbo, no power, no duals, and the list can go on and on. And Case had the nerve to call them Comfort Kings.
Kinda like this. We did this a few times with the old auger until rumers started circulating. It was only about a 5200 lb x 70 ft auger.
B&W Companion
The_Mad_Norsky
RV'ing since 1991
