tow truck
evanvalk
I have a 2008 Ram 2500 turbo Cummins diesel 6.7 4x4 everything seems to be ok except it started to be hard to start, Manual states not to operate in ideal mode to long, I was min a major back up on I75 for about one hour at not more then 2 to 3 mph. Could that cause it, Thanks for any input. Ed
ED. & ROSE.
Hartland Wilderness, 2014, 33.6 ft. 2-Slids.
2008 Ram 2500 Quad Heavy Duty 6.7,Cummins Turbo-Diesel
4X4 Big Horn. Tampa, FL
TAMPA, FL.
๐Ÿ™‚
8 REPLIES 8
Farmerjon
Don't ignore the batteries. If they aren't up to par they will cause hard starting.
2015 F350 Lariat CC LB 4x4 DRW 6.7, 6sp auto, 3.73
2000 F350 lariat SC LB 4x4 DRW 7.3, 6sp manual 3.73
1987 F250 Lariat SC/LB 4x4 SRW 460 4sp stick 4.10
1995 Jeep wrangler
99 Star Craft 953
rhagfo
enblethen wrote:
Whether it is a glow plug or Grid heater, I believe that is op's issue.
grid heater info
Not likely in Tampa!!
There are many who delete the Grid heater, even in colder weather and dot have starting issues even down to 20 degrees.
coolbreeze01
If the OP is in Tampa, doubt its the grid heater. Site above doesn't like ad blockers.........
2014 Sandsport 26FBSL
enblethen
grid heater info
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
45Ricochet
boogie_4wheel wrote:
enblethen wrote:
Hard to start when cold? glow plug issue!
Cummins = Grid Heater
:B The guy who did our PDI mentioned the wait to start light on the dash for glow plugs :W Luckily he was pretty knowledgeable about the rest of the coach.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
boogie_4wheel
Extended cranking/hard starting can point to an injector issue. Leaking injector results in a rail pressure loss, and the computer will not fire them till above 5kpsi. Result is longer cranking times to build fuel rail pressure before fuel is actually injected.
It's warm enough now that it should light pretty quickly without any intake heat.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
enblethen
Bud
USAF Retired
Pace Arrow
donn0128
Soo many things, soo little time.
Fuel filter
Time for a regen
Plugged air filter
Bad load of fuel.
I would start with filters.
