When I purchased my Chevy K2500 back in 2004, the spare tire was mounted under the bed with the valve stem up. There was no way to check the tire pressure on the spare without dropping the spare down in order to get access to the valve. So I dropped the spare to the ground, turned it over, and cranked it back up with the valve stem on the bottom.
Now, on my 2013 F350, I crawled under the back of the truck, and sure enough, the spare is mounted with the valve stem up. There was no possible way to check the tire pressure without dropping the tire. So, I got a chance to check out all the tire changing tools in order to flip the spare to valve stem down.
I wonder why the manufacturers do this? I wonder if Dodge mounts their tires this way?
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
