โJan-28-2017 05:46 AM
โJan-28-2017 11:16 AM
PAThwacker wrote:
I have a 6.0 3/4 ton sub and would not wrangle a 6100lb trailer. Same guts as any 3/4 ton truck and built to tow.
โJan-28-2017 08:42 AM
โJan-28-2017 08:29 AM
kenm500 wrote:
I am currently looking to purchase a new Travel Trailer. My current trailer, a Keystone Bullet 246RBS, has a dry wt of 4800lbs. I tow it with a 2013 Ram 1500, which is rated between 8400lbs and 9700lbs depending on the chart you use. Seems as even the dealers have a hard time answering the actual towing capacity question. The truck has no problems towing the current trailer, but I'm looking at a new trailer which is 5 ft longer and has a dry weight of 6100lbs. Should I be concerned that the weight with gear and such is getting to close to the capacity of the truck? Obviously I would prefer not to upgrade to a 2500.
โJan-28-2017 07:45 AM
donn0128 wrote:
I guess soundguy and terryallen did not bother to read my post. I emphitally said " If your truck can safely tow the trailers GVWR, then it should work OK. You may never see the trailers gross weight, but anything lower will be your safety margin."
How much simpler can I say it?
โJan-28-2017 07:31 AM
โJan-28-2017 07:22 AM
SoundGuy wrote:donn0128 wrote:
Please stop concerning yourself with the dry weight. You will never ever tow a dry trailer. Instead look at the trailers GVWR. If your truck can safely tow the trailers GVWR, then it should work OK. You may never see the trailers gross weight, but anything lower will be your safety margin.
Sure, for trailers with perhaps 1000 - 1500 lbs of CCC as that means once loaded it's GVW will end up not all that far off it's GVWR. However, many trailers offer much more CCC (heck, even my own 19' Coachmen is well over a ton!) so using GVWR as a guide just makes no sense at all as there's no way one can (or should) load so much into the trailer that GVW will ever come anywhere near close to it's GVWR. Unfortunately the OP hasn't indicated what this intended trailer's CCC may be so there's really no way one could rationally suggest using GVWR as a guide. If there's any Achilles' Heel to the 1/2 ton truck it's the rather modest payload capacity, especially if that truck has to also carry the weight of a family & some additional gear in the cargo compartment as well as accommodating any trailer tongue weight transferred to the truck. Reality is, with his 1/2 ton truck the OP will run out of payload capacity long before he comes anywhere near to meeting the truck's GCWR. In addition, the OP hasn't said anything about his particular truck's axle ratio which will have a HUGE impact on just how well it may tow a trailer this heavy. ๐ JMO, but having been towing for 10+ yrs with 1/2 tons I'd not tow a trailer anywhere near this heavy, about 6000 lbs fully loaded I'd consider about max as that will easily result in an average gross tongue weight of ~ 750 to 800 lbs, about the most I'd want to be dropping on the rear on most 1/2 tons with limited payload capacity.
โJan-28-2017 07:05 AM
โJan-28-2017 06:44 AM
โJan-28-2017 06:40 AM
โJan-28-2017 06:21 AM
โJan-28-2017 06:15 AM
โJan-28-2017 05:58 AM
โJan-28-2017 05:52 AM
