Towing with a 2014 Traverse
Colo_Native
My daughter and son in law are looking to get a TT they have 2014 Traverse 4wd with a 5200# tow rating and it has the tow package. Anybody towing with these? They are looking for something to sleep 5-6 and no soft sides.
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
12 REPLIES 12
Nvr2loud
BubbaChris wrote:
Nvr2loud wrote:
Payload Max: 1397 lbs
Your post does not say how many plan to ride in the SUV while towing the trailer.
The payload number quoted above includes all passengers and gear inside the SUV and the tongue weight of your trailer.
My post does not state how many passengers.
The 1397 lbs is maximum payload rating for the Acadia / Traverse AWD version which includes all passengers, gear, and tongue weight.
My calculation of 3991 lbs maximum trailer weight is assuming that the entire 1397 lbs of payload is used.
BubbaChris
2013 Heartland North Trail 22 FBS Caliber Edition
2013 Ford Expedition EL with Tow Package
Nvr2loud
I have an Acadia (GMC version of the Chevy Traverse)
Trailer max weight 5200 lbs
Tongue weight max without WDH 600 lbs
Tongue weight max WITH WDH 600 lbs
GCWR: 10,450 lbs
GVWR: 6,459 lbs
Therefore if the Acadia / Traverse is fully loaded including the 600 lbs of tongue weight...
GCWR (gross combined weight rating) of 10,450 lbs
minus
GVWR (gross vehicle weight rating) of 6,459 lbs
equals
maximum trailer weight of 3,991 lbs (not 5200 lbs)
EDIT: Actual allowable trailer weight in this calculation would be the 3,991 lbs as found plus the 600 lbs of tongue weight accounted for in the payload. 3991 plus 600 = 4591 maximum trailer weight at 600 lbs of tongue weight.
This only applies if the Traverse has the factory towing package coded as V92. If it does not have the V92 package the maximum trailer weight is 2000 lbs total. Adding the components later does not increase the 2000 lb limit.
easycamper
The Traverse can use a weight distributing hitch.
2015 F-150 5.0L SuperCab 4WD 3.55
2013 Springdale 253FWRLLS
People like to make generalizations.
Ron3rd
One more thing to look at is whether you can use a Weight Distributing hitch with the Traverse. Not sure if you can but the manual with tell.
Equilizer Hitch
Honda EU2000
rexlion
Dry weight around 3000 lb, loaded for camping up to 4000 lb, should work fine. One big reason we say to keep the weight at those limits is because the hitch weight on that trailer will likely end up very close to the limit, about 500 lb. In fact if the trailer has a fresh water tank up front, filling the tank could well put it over the Traverse's allowable hitch weight.
They also should try to keep the trailer as short as possible, preferably under 22' or thereabouts overall, for safe handling with the relatively short wheelbase of the Traverse. Personally I'd try to keep it under 20'.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
flash82
Also these: most are in the 3000lbs empty.
Forest River X-lite and Evo
KZ Spree escapes (196s)
Eco camp has a few different models
easycamper
Lots of options. In addition to those above:
Forest River Micro Lite and Mini Lite
R-Vision Trail-Lite
RinconVTR
To sleep 5-6 with a hard side and no canvas, they will be towing near their max. There are options in the 3500-4000 dry range that when package with you most common items, will be 4500-5000lbs.
I pulled a 23' Gulfstream Visa (now called Vista) that sleeps 5 with a Honda Pilot for 2 full summers of camping, but all within 5 hours of home. The Pilot is on the lowest end of the scale for towing, but it can be done, and it did so just fine.
OpenRangePullen
Look at these LivinLight Most start at 2,500 pounds.
2013 OpenRange Roamer 395bhs
2022 F350srw Limited, tower
2021 F150 Platinum Hybrid, daily
2002 Accord V6/5spd, project
2014 Kawasaki Concours
hddecker
Ron3rd wrote:
Yes, it can be done. The wife has the same vehicle, and personally, I would look for something 3500-4000 lbs FULLY loaded. The V6 and SUV type unibody construction will limit your choices.
What Ron said.
You say Traverse has 5200# tow rating, but the GVCW will also be a limiting factor on the size/weight that can be towed safely.
Ron3rd
Equilizer Hitch
Honda EU2000
