Oct-26-2018 05:21 AM
Oct-31-2018 10:37 AM
DaveF-250SD wrote:
To the OP,
If Subaru calls for cutting the published tow rating in half if the vehicle has to go up a hill or hills, you would do well to tow at the lower amount. That will avoid any possible damage to the car.
Oct-31-2018 08:34 AM
Oct-31-2018 06:42 AM
Oct-31-2018 05:20 AM
drsteve wrote:SweetLou wrote:drsteve wrote:
Make your case to who? Subaru will point to the clear wording of their warranty, which says only "damage from towing", not "damage from towing overweight".
Right; you stick with that theory
You assume Subaru will not enforce the plain language of their warranty terms, if it comes to that?
Oct-31-2018 05:19 AM
mkirsch wrote:
I gotta ask, if you're so confident that you know it all with regards to towing with this car, why did you even bother to ask the question? You've been on this site since 2003 so you must know what would happen when you asked about towing something with anything other than a diesel dually truck.
Oct-30-2018 07:21 AM
Oct-30-2018 06:43 AM
Oct-30-2018 04:54 AM
Oct-30-2018 04:07 AM
Oct-29-2018 11:04 AM
Oct-29-2018 07:26 AM
Oct-28-2018 09:19 AM
JALLEN4 wrote:Key phrase if its rejected. I think they need to prove that a CVT transmission was overly used for towing, or that the day you towed it was above 104 degrees. I can make my case very well. I plan to tow with it 4x a year 1500 miles each way with a light load. No issuesSweetLou wrote:pauldub wrote:
I'm not sure how you're going to drive I-15 from California to Washington, maybe you mean I-5. You'll have to go over the mountains in northern California on I-5. I'd be a bit concerned after reading the owner's manual for your 2019 Subie.
Here's one quote: SUBARU warranties do not apply to
vehicle damage or malfunction caused by
trailer towing.
Here's another quote that isn't encouraging: When towing a trailer on a long uphill grade continuously for over 5 miles (8 km) with an outside temperature of 104F (40C) or above Maximum total trailer weight 1,350 lbs (612 kg)
I didn't think I needed to explain how you get to Washington from the I-15 but just to let you know it connects with the I-90. I am leasing the car so if the trans takes a ****, its theirs not mine. It came with a tow package so it must mean you can tow with it under 2700lbs. As long as you can prove that you are under that, then the language means nothing. I think I'm safe at 1100 lbs
I don't know a thing about the towing question but I know a lot about leases. If the warranty repair is rejected, they will hold you responsible and they will collect.
Oct-28-2018 04:59 AM
trailer towing.
Oct-28-2018 04:54 AM
rjstractor wrote:I live in the SoCal Desert so the 15 is the obvious choice. Taken this route for years as we head to the east side of Washington. The road is so much better than that destroyed I-5. Not to many bad grades after the Baker grade near Vegas. Also many better choices of cites to stay and any issues on the road.SweetLou wrote:
Odd and very long route to get to Washington but very scenic. You'll cross the Continental Divide twice as well as pulling Lookout Pass on I-90 (no 'the' up here) 😉 so be ready to pull some hills. I agree though, with an 1100 pound low profile trailer you should have no issues.
