Too many variables... Basically it boils down to what you feel YOU can tow... Sure there are all the weight ratings and such.. But, I've been towing for some time and feel very comfortable towing at the limits of a tow vehicle.. Early on in my towing experience, it was overloaded, so I know what that's like too..
On the other hand, I much prefer towing at a bit less than it's max ratings, so there you go..
Where do you fall in all of that? No idea..
๐In general, if you keep your rig within it's payload specs, you'll be okay even if you've never towed anything before..
Where folks get into trouble is thinking they can tow at their max ratings the same as driving to the local store..
It does not matter if you go 50 miles or 500 miles.. If you can't handle the load, it's gonna suck..
I'd stick with something that has a GVWR of no more than #7000 with that rig.. Might still be overloaded if you put the "Brady Bunch" in the Burb, but there you go!
Good luck!
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
