Towing with Ford Escape
punomatic
I have a 2013 Ford Escape 2.0L EcoBoost. According to Ford, it develops 240hp and has a tow capacity of 3500# and GCWR of 7626 lbs. What are your thoughts about using that vehicle to tow a Forest River rPod RP-179, with the following specs: hitch wt. 285 lbs., base wt. 2630 lbs., GVWR TBD lbs., load capacity 1155 lbs.
I don't quite understand why the GVWR is TBD, when they give the base weight and load capacity. And I understand that the base weight and cargo capacity add up to 3785 lbs. We currently carry about 600# of gear in our TC. If transferred to the trailer, that would put us at 3230 lbs. Add 100 lbs for propane, battery and enough water to flush the toilet while traveling. That puts us at 3330 lbs. The Escape weighs in at 4000lbs with me and DW aboard.
So, what do you think? Is this a reasonable idea?
DW and Me
2016 Riverside White Water Retro 195
2014 Nissan Titan SL Crew Cab
Formerly, I used to work for the department of redundancy department.
Life in Black and Blue
25 REPLIES 25
rbbaldwin1
4WD you should be fine. Use a weight distribution hitch and make sue the trailer has brakes. In the Front Wheel Drive Escape, traction will be a major issue. Also make sure you have the right amount of rise on your ball mount to keep the trailer tounge level.
While I am sure this information would have been helpful, this topic is almost 10 years old.
Jeff - 2023 FR Sunseeker 2400B MBS
PAThwacker
Having owned a pup, I'd recommend an 8 ft only pup for that car. Popup camping or any type usually adds loads of gear to the tow vehicle.
2015 Keystone Springdale Summerland 257rl
Tow vehicle: 2003 GMC K1500 ext lb
Previous: 14 years of 3 popups and a hybrid tt
Mike_Up
Looked at the 2012 Escape and a 2013 Escape. We bought the 2012 Escape due to having a larger cargo area.
The 2013 was shorter in the cargo area which limited the size of cargo.
As far as limitations on towing go, the payload was only about 800 lbs with the 2013 Escape opposed to about 1050 lbs with the 2012 Escape. That low payload on the 2013 will not leave much, if any, payload left for a pop up tongue weight.
Yes it has a 3500 lbs tow rating and a low 350 lbs tongue weight rating, but the payload is what limits it the most.
I can't see anyone towing anything other than a small pop up with an Escape as short as the wheelbase is and how narrow the vehicle is.
I think the right size pop up can be done with a couple of passengers and gear, but not a small TT without going over the GVWR by a large amount. That affects handling under emergency swerves and such.
2019 Ford F150 XLT Sport, CC, 4WD, 145" WB, 3.5L Ecoboost, 10 speed, 3.55 9.75" Locking Axle, Max Tow, 1831# Payload, 10700# Tow Rating, pulling a 2020 Rockwood Premier 2716g, with a 14' box. Previous 2012 Jayco Jay Flight 26BH.
punomatic
Thank you all for your feedback. I am not imminently in the market for an rPod, so I will chew on your advice and make a decision later.
DW and Me
CptSydor
I towed a T@da with a 2013 Escape 2.0 Ecoboost AWD with tow package.
2200lbs dry, very light hitch weight. Very low profile (height and width).
Dutchman T@da
Did a bunch of 500-1000 km trips and a large eastern Canada/US trip of about 4000-5000km, including through some hills in Vermont, New Hampshire, Maine and Quebec. Generally 2 people, moderate gear, a couple bikes, sometimes on the roof.
I used just a straight hitch. It towed okay. I never felt unsafe nor was I a hazard on the road to other vehicles. My partner was comfortable towing it as well. I'm quite sure I could have set it up to tow better with a more sophisticated hitch system, but never really felt the need.
Certainly wasn't lacking power, never overheated. The added weight of the R-Pod probably wouldn't mean too much, but any additional frontal area compared to the T@da certainly would.
My opinion, I was comfortable pulling our T@da. I personally wouldn't have wanted to go any bigger. While I was comfortable and never felt unsafe, I wouldn't have wanted to add any additional burden (weight, frontal area, length) to my experience.
And in saying that, knowing I was going to upgrade the trailer, I bought and F150 this year and towed the T@da 6000km round trip to Colorado. Obviously a much different towing experience. I could definitely 'relax' a little with the larger tow vehicle. That meant a lot on the longer stretches of hwy.
lawrosa
rjstractor wrote:
I think what kills that Escape pulling the Coachman is the frontal area. The R-pod should pull much easier being more aerodynamic. It would be sad if the car could not pull its rated weight without overheating. So much for those new SAE towing standards....
Im sure there are ways to keep it cooler. My buddy has a jeep that runs hot towing a living lite.. He hooked an aftermarkey unit to put it in tow haul mode as his jeep did not have that.
Also he got a bigger fan and forced it to highspeed.
He is looking into a bigger radiator..
13 escape with r pod
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
rjstractor
2017 VW Golf Alltrack
2000 Ford F250 7.3
lawrosa
Seems cooling capacity is lacking. whether from trans or size of radiator.
Read here on real world towing of 13 escape
http://www.escape-city.com/viewtopic.php?f=41&t=21113
coachmen
living lite 13
Mike L ... N.J.
RinconVTR
Many will poo-poo towing anything with any small or mid size SUV. Its unfortunate.
In my world, it matters where you are headed and how often. If you're staying in state, 5-6 weekend warrior summer trips, and not traveling more than say...2-5 hours from home, I think your good.
The issue is not being near max, or at max, that's fine. Its that when you're there, its not going to be the most comfortable tow. You will always know its behind you and that's stressful for many. If you can deal with that, your decision is easy.
I'd also advise using a WDH. The soft SUV springs will thank you, and you will feel more connected and in control of the trailer, not to mention it will level you out.
rjstractor
I'm going to go against the grain and say you will have a good combo if the hitch is set up correctly. You've done your weight figuring conservatively and still under GCWR. The R-pod is an aerodynamic shape, not a box on wheels and this will make a big difference in how well it tows. With 240 hp and 270 ft./lbs of torque moving just 7500 pounds you will be able to keep up with traffic on any hill you can find. I used to have a Ford Aerostar and I towed a 1000 lb. heavier trailer with 110 less horsepower and 40 ft./lbs less torque and power was adequate to pull mountain passes at 50+ mph.
2000 Ford F250 7.3
carringb
Everyone I've talked who tows with their Escape loves it. The only time I've seen a problem was coming down Snoqualmie pass, where an Escape jackknifed coming down the hill on the right-hand curve. I don't know what led up to the incident (other than there was very heavy traffic), but it was a 26'-ish trailer with a slide out, so they were running very heavy.
2014 ORV really big trailer
2015 Ford Focus ST
wintersun
With the Escape I would tow a trailer with a dry weight of 1500 lbs. or less. Above all else I want to have 100% certainty that if the trailer brakes malfunction in any way for any reason that I can still bring the vehicle and the trailer to a full stop in a reasonable distance.
My 1998 Chevy Tahoe could according to GM, tow 7,000 lbs. but with a 3,000 lb. trailer load it would take more than 300 feet to bring it to a full stop from 60 MPH. It was not safe and so I avoided towing with it.
Need to differentiate between the maximum tow load that will not distort the frame or overload the engine's main bearings, the cooling system, the transmission, drivetrain, axles and wheel bearings, and other key parts of the vehicle, from the load that can be safely towed on freeways and over mountainous terrain.
As was mentioned the square footage of the front of the trailer is also very important as this generates the air drag that the car's engine also has to overcome and this increases with the square of the speed and you need to factor in a 15-20 MPH headwind as well.
For a car like the Escape I would be looking at the Casita type of trailer or one of the popups that collapse to half their expanded height for travel. I have seen many of the Casita trailers being towed by small SUV's and station wagons and their owners have all been very happy with them.
ib516
TBD = to be determined
I think it'd be ok for short trips on level ground, but not much more.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
