Towing with Ford Escape
punomatic
I have a 2013 Ford Escape 2.0L EcoBoost. According to Ford, it develops 240hp and has a tow capacity of 3500# and GCWR of 7626 lbs. What are your thoughts about using that vehicle to tow a Forest River rPod RP-179, with the following specs: hitch wt. 285 lbs., base wt. 2630 lbs., GVWR TBD lbs., load capacity 1155 lbs.
I don't quite understand why the GVWR is TBD, when they give the base weight and load capacity. And I understand that the base weight and cargo capacity add up to 3785 lbs. We currently carry about 600# of gear in our TC. If transferred to the trailer, that would put us at 3230 lbs. Add 100 lbs for propane, battery and enough water to flush the toilet while traveling. That puts us at 3330 lbs. The Escape weighs in at 4000lbs with me and DW aboard.
So, what do you think? Is this a reasonable idea?
DW and Me
2016 Riverside White Water Retro 195
2014 Nissan Titan SL Crew Cab
Formerly, I used to work for the department of redundancy department.
Life in Black and Blue
25 REPLIES 25
DownTheAvenue
lawrosa wrote:
Jayco makes some light stuff. You can get 20 footer/ more trailer with a dry bath..
Just an example
Jayco
Coachmen clipper is an option too with dry bath...
http://www.coachmenrv.com/product-details.aspx?LineID=63&ModelID=301#Main
A square bodied conventional RV will push that escape all over the road! It will be way more than just the tail wagging the dog!
rexlion
A few people on another forum I frequent are towing with that Escape Ecoboost, and they say it does well enough for them. Most are towing molded fiberglass "egg" trailers, but one guy had a regular stick built TT and he said he had no trouble towing at 70 mph (not saying I approve, just relaying the info).
You will need to monitor your hitch weight closely to make sure it's under 350 lb.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
lawrosa
Do you have the hitch on already? Was it the tow package from the factory? I think they only installed class II hitches and none WD...
I would be leery of that...
http://www.ford.com/resources/ford/general/pdf/towingguides/13flrv&tt_escape_oct1.pdf
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
lawrosa
Just an example
Jayco
Mike L ... N.J.
cummins2014
Having ,and driving the 2013 Escape for over two years now, but have never entertained the thought of towing with it . Will be interesting to see how it works out for you
blangen
mbutts wrote:
I think you'd be really unhappy towing that close to the limit of your Escape.
X2. Even if you can get the numbers to work, I don't think the experience will be pleasurable. Take it to an equipment rental yard and rent something as close to that weight as they will allow. Take it for a drive. Let us know what you think.
lawrosa
mbutts wrote:
I think you'd be really unhappy towing that close to the limit of your Escape. Although the r-pod is compact, you'll probably be over the 20 square foot trailer frontage limit that Ford suggests.
Ford 2013 Towing Guide (see page 13)
Its actually 30 sq ft...
Youll probably be fine IMO..
R pod 179
You will need a WD hitch though and watch your axle weights. That 285 lbs TW will be more.
What you should do is fill the escape with gas, people, and cargo like going camping and take it to a cat scale. Get those #'s and post back. Compare that to the axle ratings of the escape. That will tell you if you have payload left for TW..
Also a trans cooler is a must. Get the biggest you can fit... Then if you have engine heat issues after the trans cooler is installed then an oil cooler will be needed...
Also your tire ratings are important because the tires carry the load. What are your tire weight ratings at max psi?
That escape has similair specs to my old s 10 p/u. I tow 4500 lbs wet..
Mike L ... N.J.
RWDIII
you need a nice pop up,like an Aliner.I had one for years with a 175 hp Tacoma
OLD 2006 F150 4wd 7200gvw,Lt275-65-18,Scan Guage,Garmin,flowmaster,load levelers,Firestone work rites Bronco 800
NEW 2015 F250 Scab 4wd 10000 gvw, 6.2 Scan guage,Garmin,work rites,3200 lb load,1800lb Palomino Backpack SS1200
punomatic
Actually, the guide says 30 sq.ft. for the 2.0L EcoBoost. I was wondering if that means total frontal surface or only the part that exceeds the frontal surface of the car. Do you know?
DW and Me
kaydeejay
Don't forget the towing capacity is reduced by everything in the vehicle except for a 150# driver.
So, IMHO, not a good match.
Escapes can make good toads, not towers!
Keith J.
Sold the fiver and looking for a DP, but not in any hurry right now.
mbutts
Mike Butts
DW+DD+DS+Poodles
2017 Forest River Forester 3011DS (first MH!)
Previously 1999 Coleman Santa Fe pop-up, 2007 Kodiak 23SS hybrid, 2013 Sunset Trail 29SS travel trailer
