โJul-29-2019 05:41 AM
โAug-02-2019 06:06 PM
Grit dog wrote:
A 15 passenger van has a lot of tail to wag compared to a pickup for towing duty.
Just a consideration, but not a deal breaker? Never towed with a long tail van but itโs probably not much different than a truck with a long hitch extension?
Otherwise , I think youโre thinking right. Low miles like new, LOTS of extra room, low cost, low depreciation.
Best part is the trip to AK! Iโd do it in a Hyundai if I had to, just to go!
โJul-31-2019 05:24 AM
โJul-31-2019 04:51 AM
CJM1973 wrote:
I think these vans are hidden gems if practicality is the main objective.
โJul-30-2019 11:19 PM
blt2ski wrote:
IF I could have gotten a 4wd 3500 extended van, I would have over a crew cab for my family of 6. I towed to the local mountains and used my TT as a ski hut more than I did in the summer months. So 4wd was a must to get thru the upwards of 3-5' of snow it snowed a few times over a weekend, getting stuck at pass as it was closed due to avalanche danger etc......
FOr what you are doing, a G80 rig is as dang near as equal as an open diff 4wd! There are a few things about 4wd that make it nicer, but having had multiple rwd G80 rigs, dang near unstoppable in there own right.
I drive a work 9500gvwr vans with 14' boxes, bassically a 15 passenger version. I have a transit now, a Sprinter before. I'd take the sprinter with 5 years and 180+K miles over this POS transit I have now. The shorter wb makes it ride worst IMHO. Put a load in the back, you have many lbs taken off the FA, vs the longer WB of the sprinter was better. I think you will find a GM will ride much like the sprinter did from my standpoint. I would suggest one, but feel the 6.0/6 sp will be a better power/drivetrain than the 200/400 6 cyl diesel in the Sprinter. If you were towing a smaller trailer, say 6-8000 lbs, then yes, but it would be slower than the GM van.
Marty
โJul-30-2019 10:29 PM
โJul-30-2019 10:26 PM
โJul-30-2019 07:51 PM
If you are talking about the rear overhang, itโs pretty much exactly the same between the 12 passenger (regular wheelbase) and 15 passenger (long wheelbase). All of the extra length goes into the wheelbase.
The Express/Savana will actually ride better loaded than not, that is my experience. The shock upgrade is a must. I also put Belsteins on our van and it rode much better loaded and not. If we werenโt going to be towing for extended times I would deflate the tires a considerable amount. I think I would reduce the rear from 80 to 50 PSI or less.
We towed a 7200# gvwr 32โ trailer and the van did great. I donโt think I ever used anything less than 4th gear in the Northern Michigan Hills (Cadillac, Gaylord), so even in the mountains you should have plenty of gears to choose from. There was times the van was actually content towing in 6th gear, which was impressive considering my 2004 3/4 ton Suburban with the 3.73 couldnโt hold speed in 4th. Kind of proves that the 3.42 may actually be the right gear in the van.
โJul-30-2019 07:22 PM
โJul-30-2019 01:37 PM
Grit dog wrote:
Plus if you buy it right, it may not even cost โa few thousandโ in depreciation. Unless you plan on putting on a bunch of miles. Just 10k or so for the trip will be virtually unnoticeable.
โJul-30-2019 01:33 PM
Grit dog wrote:CJM1973 wrote:Dadoffourgirls wrote:CJM1973 wrote:Bionic Man wrote:
Not trying to talk you out of your plan, but 145k miles really shouldnโt be a huge concern, especially if you have maintained the truck.
If my plan didn't involve upgrading trucks in 1.5 years and if my children didn't grow like weeds, I think I wouldn't even consider it. But the lack of space behind the front seats is a concern for a 14,000 mile trip over 2 months. I think the storage capacity with the rear 2 rows removed (it's a 2-3-3-3-4 config) is the biggest plus. Will be able to bring a few more things with us and keep it all out of the elements.
Just be aware that you will then find yourself hauling the Scouts, 4-H, band, drama, kids etc with this vehicle. It will make a great, one-day road trip vehicle to Grand Rapids. 5 couples can go, and you need only one designated driver.
That's what I'm afraid of....the DW and I being the designated driver all the time.
Thatโs easily cured. Just be the first one in the group to get snot slingin drunk and whip out the keys and yell โwho want to go do some donuts in the parking lot!!โ
Youโll be absolved of that duty then....
(Thatโs what I do anyway. Works most of the time!)
โJul-30-2019 09:37 AM
โJul-30-2019 09:36 AM
โJul-30-2019 09:31 AM
โJul-30-2019 07:23 AM
CJM1973 wrote:
As I have yet to drive any distance in a 1 ton van, how do they ride over the long haul as compared to a 3/4 ton pickup truck?
