Towing with Toyota Tacoma
john_d_dobbs
I'm considering a new truck, perhaps a Toyota Tacoma. How much do you pull (would you pull) with a new V6 Tacoma with auto trannie? The towing capacity specs are towing capacity 6400 lbs and tongue load 640 lbs.
Thanks,
John
20 REPLIES 20
rexlion
I had an earlier version of the 3.5L in my 2008 Highlander, and I towed trailers in the 2700-3500 lb range for about 140,000 miles (yes, that many miles of towing, work and play). It held up well and performed decently. Towing up a long grade at higher elevation (Rockies), I liked to take it in 3rd gear at about 40-45 mph so the tranny wouldn't get too hot.
Keep in mind that 650 lbs hitch weight is not much. This will be your limiting factor. You should assume that a TT with 450 lb dry hitch will be about all you'd want, because once you add LP, battery, water and gear that tongue weight will climb fast. So you are going to be looking at trailers weighing probably less than 3500 lbs (dry weight) or so, and maybe no longer than 25' (if even that). I'd also recommend TTs no wider than 7.5' and not overly tall, to keep the frontal area as small as possible; frontal area is a bigger factor than weight when you tow on a typical highway, and weight becomes more critical going up and down steep grades. My TT was 7' wide and only 99" high; the other trailer for work was a 6x12 cargo.
I hope that helps.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
ib516
For occasional towing within the specs, it will do fine.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
trailernovice
We had a v6 tacoma pulling a 19 foot tt .. after one trip, traded up to a v8 tundra.. keep within limits, you may be ok on flat ground.. any little hill, though, with anything bigger than a popup, and you may quickly run out of power
Glenn and Toni
2019 Jayco JayFlight SLX8 264 BH
2019 Ram 1500 5.7 3.21 gears
Reese round bar w/d with sway control
2001400ex
I personally wouldn't tow anything more than a couple quads on a flat bed with a Tacoma. Tho there are many light trailers you can tow with a Tacoma and I have friends that do that. I just wouldn't after my years of experience. You can also get a half ton pickup for not really much more money and really not that much worse fuel economy.
2017 Forest River Stealth SA2816
2020 GMC Denali 3500 Duramax
Anderson ultimate fifth wheel hitch
Lwiddis
โ€œget a truck with ample capacity.โ€
And for all but the smallest trailers, the Tacoma is inadequate.
ScottG
My suggestion is if you want to tow, get a truck with ample capacity.
