Dec-01-2018 08:02 AM
Dec-02-2018 05:26 AM
theoldwizard1 wrote:
No proof, but I think some states REQUIRE WDH on trailers over 5000 lbs. Brake for sure.
Dec-02-2018 04:35 AM
Dec-02-2018 04:31 AM
Dec-01-2018 11:38 PM
Dec-01-2018 07:06 PM
Gdetrailer wrote:ScottG wrote:
Probably "OK" without it but it will tow a lot nicer with it.
The answer is "maybe".
From my understanding, spring rates between F250 and F350 with 9900/10K GVWR ARE the same, may not be the case with your Dodge so with the Ford F250/350 the "ride" quality is pretty much the same.
I suspect that most likely there will be very little "ride" quality improvement with the OPs setup with WD.
All of my F250s I have all ride very firm, no mushy soft F150 ride.
As I mentioned, the OP and my own situation is nearly the same, the ONLY thing that WD might improve is the small amount of front end "porpoising" (UP/DOWN) that sometimes happens under some road conditions. I have never had this fell like it has been excessive or out of control.
OP may or may not like that movement, if not objectionable they could SKIP WD.
IF they find the slight porpoising they get is objectionable then they MIGHT want to LIGHTLY apply some WD.
Otherwise they most likely will never be able to tell the difference between WD and no WD.
In some cases, the application of WD CAN adversely affect ride quality and possibly cause instability especially when attempting to fully return the no load front ride height. It is for that reason manufacturers like Ford, no longer recommend attempting to return to no load front ride height, it is not needed. Instead opting for PARTIAL OR HALF ride height as the recommendation.
Folks on this forum are totally obsessed with WD and restoring front ride height, sometimes it is not needed, the rear height of the truck IS CONSIDERABLY RAKED and you have a HEAVY ENGINE/TRANSMISSION on the FRONT AXLES.. If a truck cannot handle 900-1000 lbs at the end of the frame it doesn't deserve being called a truck..
For the record, I do have 3400 lbs of cargo capacity, I HAVE loaded more than once 3000 lbs of cement blocks in the bed of my truck.. Never, not once had "light steering" or any driving issues.
Dec-01-2018 06:56 PM
Dec-01-2018 06:07 PM
Dec-01-2018 03:05 PM
Dec-01-2018 03:02 PM
Dec-01-2018 02:31 PM
Dec-01-2018 02:07 PM
Dec-01-2018 12:42 PM
4x4crazy wrote:
I'm looking at new jayco jay feather trailers and in specific the 24rlsw model. Weight is about 5200lbs dry 7000lbs gross. I'd be pulling it with my 2017 f250 super duty with the diesel. Debating if I should even use load leveling or sway control. Ford says there's no need. My truck also has a built in sway control. Ive read of people towing much more without load leveling hitches with this truck and it's almost thr same weight as my boat. ..im more concerned if not having a weight distribution hitch will be a big issue if I ever go sell it. Looking for opinions
Dec-01-2018 11:20 AM
Dec-01-2018 10:56 AM
Dec-01-2018 09:52 AM
