โJul-17-2013 10:42 AM
โJan-09-2020 03:04 PM
โJan-08-2020 09:22 AM
Waynrdude wrote:
Hello, would you still have your 225 RBS Shadow Cruiser? If you do I have a friendly request. I had a blow out and the tire destroyed the wiring that goes to the slide, both 12v for light and 110v for receptacles. I have the slide end of the wiring under the dinette, no problem there. The problem is where the wires go into the "basement". There are two wire ties on the outside bottom of the slide but I can not see where the wires go for power. Is there a "curly" wire that retracts? With the room extended a photograph would truly help where to start digging for the wire. I would like to thank you in advance if you could help. The manufacture is useless, they won't even answer an email. Wayne
โJan-08-2020 06:45 AM
โJul-18-2013 09:09 AM
โJul-18-2013 07:12 AM
โJul-18-2013 06:36 AM
โJul-18-2013 05:59 AM
โJul-17-2013 07:59 PM
โJul-17-2013 04:40 PM
gon2dadawgs wrote:
Thanks for all the thought out replies! Funny cause Tundra was in second place. Time to compare capacities, years, engines....and so on.
Oh yes, going from 165" wheelbase?, DRW, Cummins....gonna be a big change...its the one ton suspension and mechanical (P7100 pump) noisy diesel. 230/605 TST plate, lots of power, but we were pulling 10k.
Michael
โJul-17-2013 04:31 PM
โJul-17-2013 04:13 PM
โJul-17-2013 03:00 PM
โJul-17-2013 01:00 PM
โJul-17-2013 12:52 PM
gon2dadawgs wrote:
Firstly who is gonna pack 3115 in a camping trailer!?
