TPO versus EPDM
Yardvarkers
Hello. I own a Jayco Eagle and I will be trading for a new 2018 Grand Design Imagine travel trailer in the next few months. My Jayco has an EPDM roof. The Grand Design has a TPO roof. Which type is better? I think the TPO is better than the EPDM but there's probably different opinions about that. Any opinion and suggestion will be greatly appreciated. Thanks, C. Miller
"Any good that I can do, or any kindness that I can show to any fellow creature, let me do it now. Let me not defer or neglect it, for I shall not pass this way again."
- William Penn
13 REPLIES 13
LVJJJ
black streaks come from good 'ol dirt on the roof.
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
Atlee
Mine is TPO but still gets black streaks.
TurnThePage wrote:
Rubber (EPDM) roofs shed material over time. This is the cause of those evil streaks on the the sides of trailers. I don't think TPO has that problem.
Erroll, Mary
2021 Coachmen Freedom Express 20SE
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
Equal-i-zer Hitch
TurnThePage
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
tinstartrvlr
One small difference I noticed is the TPO, because its surface is a little like orange peel, it's not as slippery as the smooth rubber. Feel a lot safer on the roof with the TPO.
SoundGuy
Yardvarkers wrote:
No. I don't know what the TPO type is. I'm sure that it has a fabric backing though.
In simple terms TPO is vinyl, EPDM is rubber. About 10 yrs ago Jayco for a period of time was using felt backed TPO on some models until it was later discovered that the felt was wicking in and retaining moisture. I know of no TPO membrane used today that has felt backing and given the choice would prefer TPO over EPDM. Our current Coachmen has an EPDM roof and as is typical has the odd wrinkle, our previous K-Z Spree had a TPO roof which was perfectly flat & even throughout.
2012 Silverado 1500 Crew Cab
Bumpyroad
TPO vs rubber. no contest
TPO all the way, not fabric backed however.
bumpy
rbpru
If your roof leaks it usually not the materials, it is one of the numerous seals that has started to leak.
Every manufacturer will tell you why they use what they use and why it is superior to the other materials.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
Atlee
The TPO roofs that Jayco currently uses do not have a felt/fabric backing. The TPO roofs used to have felt backing which caused water damage because the felt would get wet and stay damp.
Erroll, Mary
Equal-i-zer Hitch
Lwiddis
โ€œI'm sure that it has a fabric backing though.โ€œ
So what? You have already decided to buy the Grand Design. The horse is out of the barn. Closing the gate makes no difference.
mbopp
Grand Design uses an Alpha Systems TPO roof.
BTW - there are very active Facebook pages for Grand Design & Grand Design Imagine owners.
2019 F250 XLT Supercab
Just DW & me......
Yardvarkers
- William Penn
Lwiddis
Havenโ€™t you already decided to buy the new RV? So if one was better than the other...?
JBarca
Nomad II
Nomad II
From my experience, both the physical EPDM or TPO membrane are both good. There are some different types/vintages of TPO. Do you know which are coming on your new camper?
The problem with both is the sealants used at all the edges and roof penetrations.
Have fun with the new camper.
Thanks
John
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
