Trailer Weight
milo
Evening ...I have a stupid question about figuring our TT weight. Our Cougar has a GCWR of 9450 lbs. Weighted loaded for travel, the axle weight was 7600 (truck scales) and the tongue weight (my Sherline tongue scale) is 920 lbs. Now is my trailer weight 7600 lbs (axles only) or is it 8520 lbs (Tongue & axles weights together)? :h
Thanks
Milo
Janet & Milo ...47 fantastic yrs 2gether :B
Mona Yorkie & Buddy our beloved Beagle (both in spirit)
2013 F-150 Kodiak Brown XLT 4X4 HD Ecoboost
2014 Cougar 26sab
Living under the best Government money can buy ... Bob Brinker ๐Ÿ˜‰
8 REPLIES 8
milo
Thanks, very helpful
2014 Cougar 26sab
ktmrfs
I believe the correct answer is :
the OP has not given enough information to answer the question.
the unknown is does the OP have a WD hitch? and if so, were the spring bars hooked up when the axle was weighed?
If the answer is no WD hitch or no spring bars hooked up, then the actual trailer weight is the sum of the tongue + axles +/- scale resolution for each weight +/- scale accuracy. (likely somewhere between 25 and 100lbs scale resolution)
If the answer is "I had the spring bars hooked up" THEN the unhooked trailer axle weight will be lower than the scale weight because it includes the weight transferred from the TV rear axle. So the real trailer weight is less than the sum of tongue + axle.
the axle LOAD in either case is the weight shonw on the scale, so the axle must be rated for at least that amount.
2011 Keystone Outback 295RE
bartlettj
The resolution on most truck scales is in 100 pound increments.
MontanaCamper
We have a scale that is 40' long by us. I weighed the tongue, then pulled on and weighted just the axles. Then backed up and put the whole trailer on and it was like 100 pounds difference, all the trailer weighed more....not sure why. Its not a scale that is for public use, the scale is for a trucking company that weighs dump trucks, etc.
'07 301BHS FOR SALE
'07 Dodge 2500 w/5.9L SOLD
'96 wife
4 dogs
2 cats
10 rc's
Been pulling a trailer for 16 years
2013 camping nights: 16
2014 camping nights: 28!! Then tranny went out........
skipnchar
Every pound counts whether it's on the tongue or the axles.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
fla-gypsy
Rubber Ducky1 wrote:
Your total trailer weight is 8520 lbs. (axles + tongue weight)
X2
Old-Biscuit
Both......
Rubber_Ducky1
