Trailer with slight forward rake?
JCR-1
It would seem that a slight downward rake at the hitch (trailer nose slightly down from level) might be beneficial for several reasons. Weight distributed forward when moving (more tongue weight better sway control). Little less wind resistance (negligible) and a slightly raised rear bumper and tank valves slightly higher (negligible)for backing . What would be the downside.. ???
5 REPLIES 5
Huntindog
I experimented once by weighing the tongue at level, vs. a couple of inches down. The difference was so slight as to be a non factor.
Slightly nose down can be a benefit in that it may on some setups reduce porposing
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
PartyMarty
I tow slightly nose down, maybe 2 inches.
We do some dispersed camping .
We need the clearance in back of the trailer .
Because we use an HD 2500 gmc to tow a 24 foot OAL trailer we have no issues with a slight downward rake .
astraelraen
A lot of sites recommend you put the ball on the tow vehicle higher than the coupler on the trailer.
I could never get this to work on my F150, I had to lower the ball by about 1 1/2 inches to get the trailer to sit level. It seems like they want the weight of the trailer to "push" down the ball and rear suspension.
Is this a function of trailer weight vs suspension of the tow vehicle as to how high the ball should be? Maybe the trailer did not weigh enough or the suspension was too stiff to properly align the tow vehicle and trailer?
2013 F150 Crewcab Ecoboost Max Tow
3.73 gears 157" wheelbase
Nomadac
When towing a dinghy with a MH it is recommended it be level with the receiver ball. If during an emergency stop if the tow bar broke of came disconnect it could submarine the rear of the MH. If during an emergency stop the tow vehicle would have the rear raise as the front dropped and the same thing could happen with the trailer. Level during towing is always recommended. JMO
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
2004 Honda Pilot w/SMI Air Force One Brake Sys.
1963 Pontiac Grand Prix 20' Enclosed Car Trailer
beemerphile1
Downside could be overloading the front axle of trailer. Level is best, slightly nose down is next to best.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
