Jul-10-2018 05:35 AM
Jul-16-2018 07:43 AM
crcr wrote:
What do you mean, "Honda manual transmission fluid" -- I wasn't aware that any late model Hondas offered a manual transmission option.
Jul-16-2018 07:22 AM
crcr wrote:Maury82 wrote:crcr wrote:thomasmnile wrote:
Toyota like so many other manufacturers is using 'sealed' transmissions with fluid that supposedly never requires/requires infrequent changing. With the 2018 Camry 2.5L engine, the factory fill motor oil is now 0w-16 (and per the manual is the ONLY oil to be used unless you can't find 0w-16, which is just appearing in the US market). Hard to wrap my head around, but Toyota has been using 0w-16 on its Japanese vehicles for 2 decades. Guess we'll see how it plays out, especially driving in Florida in the summer months.
Our 2014 Honda Accord specifies 0W-20. I use Mobile One Synthetic 0W-20.
Same here with the Mobil One full synthetic. I don't trust Honda manual transmission fluid, so after breaking the car in, I immediately dumped the factory gear fluid and put in Penzoil Synchromesh gear fluid, and the shifts are smoother, and the engine revs more freely.
Jul-14-2018 01:09 PM
Jul-14-2018 12:35 PM
Jul-14-2018 05:33 AM
Jul-13-2018 11:00 AM
silverfz wrote:
On my tundra i just did my first transmission service . Drained 4 qt out and out 4 qt in at 140k. Mine is a full sync world ATF and it is suppose to be lifetime. i plan to do it another one in 60k.
Jul-13-2018 09:03 AM
Jul-10-2018 08:41 AM
Jul-10-2018 08:25 AM
Jul-10-2018 08:12 AM
Devocamper wrote:falconbrother wrote:
My old burb was designed for Dex III. I have of course been using Dex-6 on the occasional drain and fill. I went to the store to buy some Dex 6 the other day and all they had was a synthetic Dex-6/Merc-LV. I read the label and it reads like a fluid that replaces the above two plus some import fluids. I suppose I will run it and not worry about it. But, as a general rule, I haven't been a big fan of the multi use fluids.
probably does not matter at this point but dex 6 was not backwards compatible with dex 3 at least not in the Allison transmissions dex 6 would damage the seals for some reason there was a certain manufacturer date for the change over, look for the material standard number if it is on the bottle it should be ok .
Jul-10-2018 07:48 AM
Jul-10-2018 07:40 AM
Jul-10-2018 06:59 AM
Jul-10-2018 06:58 AM
