Jan-06-2019 12:16 PM
Jan-08-2019 06:18 AM
Jan-08-2019 04:11 AM
Jan-08-2019 03:39 AM
Jan-07-2019 06:44 PM
Jan-07-2019 03:57 PM
Jan-07-2019 12:13 PM
twodownzero wrote:MitchF150 wrote:old guy wrote:
all I can tell you is a 1/2 ton and a 3/4 is like night and day difference. I used to tow with a 1/2 ton and with the trucks passing you or the wind in general, power, and the truck being able to perform, a 3/4 will not let you down in satisfaction and safety. I would only buy a 1/2 again if all I wanted was to haul a sheet of plywood. I believe in my 3/4 ton that much
Really.... Man I thought I was out of touch with things...
Mitch
I actually agree with this. I wouldn't have a household without a 3/4 or 1 ton pickup truck. Buying a 1/2 ton truck knowing that you're going to be trailering is not well advised. 1/2 ton trucks are designed for people who mostly want a truck, but do not need a truck. While they have become more capable over time, they lack the features that come standard on 3/4 and 1 ton trucks for trailering.
Do 1/2 ton trucks work for trailering? For the right trailer, sure. But can you honestly say you would rather tow 8000 pounds with a max payload package 1/2 ton vs. a random 3/4 ton? The 3/4 ton comes with heavier springs, a full floating rear axle, lower gears, a heavier duty transmission, maybe overload springs, and E rated tires. And that's without specifying any additional options!
To me that's a no-brainer.
Jan-07-2019 11:20 AM
Jan-07-2019 06:51 AM
ppine wrote:Not really amazing at all. The larger truck doesn't come with the 3.5 ecoboost and 10 sp transmission. When used as a Daily Driver and a Sometimes tow vehicle, and used within its ratings, this combination is the real "no brainer".
It amazing that so many people want to buy "just enough truck" to pull their current trailer. Most people go through many different RVs over time. The cost of a 3/4 or one ton is not much different than a 1/2 ton. I agree that buying a larger truck is a "no brainer."
Jan-07-2019 05:42 AM
Jan-07-2019 05:08 AM
willg wrote:
This is surly not the first post like this and probably not the last, but I am a newbie looking at purchasing a Rockwood mini lite 2304s dry wt. 5654, GVW 7660. I have never towed before. Finding the right tow vehicle is down right confusing so i”m looking for some advise from the experts! I don’t feel comfortable taking advice from car and rv sales people. Don’t want to overkill it, but also don’t to want to be underpowered driving in the mountains which will be a minimum of once a year up to the North Carolina mountains (Linville area). I’m assuming a 1/2 ton is sufficient. Looked mainly at the Ford F 150 2.7 and 3.5 EcoBoost engines so far. Thinking the 2.7 is too small. I would like any and all advice on any of the big 3 pickups but mainly advice on the appropriate pickup engine for the weight of the trailer. Thanks
Jan-07-2019 04:49 AM
twodownzero wrote:
... Although others here might suggest you will be fine with a 6 cylinder engine, I would strongly recommend against that no matter what any salesman, marketing document, or review online states. Get at least a small V8.
Jan-06-2019 07:45 PM
Jan-06-2019 06:57 PM
Jan-06-2019 06:03 PM
camp-n-family wrote:
You need to look beyond the tow ratings and consider what you plan on carrying in the truck as well. Any of today’s 1/2 ton trucks has the tow rating to handle the tt you are considering. The payload rating will likely be the limiting factor, not the tow rating. Estimate the weight of everything you plan to carry in the truck plus the loaded tongue weight of the trailer then find the truck that has the payload to carry it all.
Jan-06-2019 05:32 PM
