Feb-21-2014 10:38 AM
Feb-22-2014 08:50 AM
Feb-22-2014 07:16 AM
Feb-22-2014 05:25 AM
Feb-22-2014 05:19 AM
free radical wrote:Steelhog wrote:
So much of the gas/diesel question hinges on your usage pattern. Lots of miles, mountains, weight, majority with TC on-board favors diesel. Occasional use, truck stays parked except for once a year trip gas may be a better option. The issue with diesels is they are never cheap to fix. AND as they age stuff gets tired. A set of injectors are $1000 just in parts. A new trans =$3000++. New engine $12,000 or $5000 for a rebuild. Gasser parts are just cheaper. UNLESS...(back to my initial point). OK, I can buy a rig like my 2002 F250 4X4, CC diesel for 10K with 170,000 miles and have the trans drop out the bottom 10 miles down the road. Bingo $17K truck. The 4R100 Ford trans is decent but once overheated (the OEM gauge only indicates you just bought a trans)they are toast and a prime time to dump them so the new owner "discovers" the problem.
Wish I had dually for the TC but the other 340 days a year I don't need to be wearing out 2 more tires. You mention blowouts but you don't have duals on the front so you never really have full redundancy.
Read a lot of forums. Avoid the Ford 6.0 as a used truck. You can bullet proof them for $3-4,000 but then you are back to a newer truck or different maker.
(IMO) Dodge has the best engine with the Cummins. GM has the best Trans with Allison and Ford has the best chassis and interior. If I could build that combo I would be in heaven but then I'm spending $30K.
Excelent points,
however
,Chevy chassis is way better stronger then Ford see this
http://youtu.be/TKMQjm7i2Jw
Feb-22-2014 04:35 AM
Feb-21-2014 08:24 PM
Feb-21-2014 07:50 PM
Feb-21-2014 07:34 PM
Feb-21-2014 07:26 PM
Feb-21-2014 07:18 PM
Feb-21-2014 06:28 PM
Feb-21-2014 05:26 PM
Feb-21-2014 04:56 PM
cewillis wrote:
I know for a fact that one can (sometimes - if they're lucky) buy an 'older', low mileage, diesel, SRW 2500hd, meticulously maintained and upgraded to better than 3500 SRW (same year) capacity, that can easily carry 3000 lbs, for half or less of $60000. I know because I have one that I bought new -- (and I'm damn sure not going to sell it).
Add a moderate size, high quality used camper for $15000, and you're at half your new price estimate.
Feb-21-2014 04:35 PM
Feb-21-2014 04:08 PM
