โJun-30-2014 05:02 AM
โJul-02-2014 02:13 PM
brulaz wrote:
In some places, my coroplast bends down in the centre around tanks and supports. If travelling on a wet day, water can get in and accumulate in these low spots. Probably not a good thing. Others have (I intend to) cut or drilled some drain holes at these low points.
โJul-01-2014 07:12 PM
โJul-01-2014 05:35 PM
LarryJM wrote:On mine the factory had used 1x4s across the span of the frame rails to screw the coroplast into.Huntindog wrote:
I took all of mine down, and installed pipe insulation and heat tape on all of the plumbing.
Then I used a polyisicronate (sp) R7 insulation to insulate the inside of the frame rails and across the bottom,(like a insulated basement) just above where the coroplast is. I added another heat vent right next to the fresh water tank. When I reinstalled the coroplast, I cut it into smaller overlapping sections so that when I need access in the future it will be easy.
This mod was intended for freezing weather, but a side benefit has been in the summer. The AC now can keep it cooler. Propane use has declined dramactically in cold temps as well. To the point that it will pay for itself in short order.
I did something similar, but went a little higher tech with using aluminum angle iron for each coroplast section cross support, all nylon bolts/washers for corrosion prevention and re routed all my propane lines from running across the underbelly to alongside the frame for better protection and to make removing the coroplast sections easier. Like you I also added a lot of additional insulation along with putting in some extra tank supports.
I photographed and documented what I did in the caption in THIS ALBUM
Larry
โJul-01-2014 04:36 PM
โJul-01-2014 04:17 PM
โJul-01-2014 03:17 PM
โJul-01-2014 09:08 AM
โJul-01-2014 07:44 AM
โJun-30-2014 06:45 PM
โJun-30-2014 06:35 PM
โJun-30-2014 04:34 PM
โJun-30-2014 02:51 PM
โJun-30-2014 05:21 AM
