โJul-21-2014 01:26 PM
โJul-22-2014 11:59 PM
shodobe wrote:
I have 4" at the top and 5" between wheels, so that shouldn't be an issue. So if I was to go with a 16" E rated tire vs a 15" E rated trailer tire, was is the advantage for the added expense of changing out all of my rims? This is a TT by the way.
โJul-22-2014 05:10 PM
rbrumm wrote:
So having 14" wheels on torsion axles that have 2" of clearance between the tires, I'm kinda screwed on that upgrade huh.
โJul-22-2014 01:03 PM
shodobe wrote:Lots of people "know" What they don't "know" is just what tire you want to put on said rim. The answer is easy if you know what SIZE tire you are mounting on the rim. There are MANY sizes and load ratings that will fit on a 16" (or other size) rim. Pick your size and look it up on the manufacturers website.
Also, my question on the difference between a 15 and 16 E rated tire.
โJul-22-2014 08:00 AM
โJul-22-2014 05:46 AM
โJul-22-2014 05:35 AM
shodobe wrote:
But so far I haven't been given a good answer as to why people change. Also, my question on the difference between a 15 and 16 E rated tire. Seems no one knows the answer. I probably will change next year because I have too much invested in new tires right now.
โJul-22-2014 03:17 AM
shodobe wrote:You have received very good answers. They just are not the ones that you want to hear.
โJul-21-2014 09:20 PM
โJul-21-2014 06:43 PM
โJul-21-2014 06:09 PM
โJul-21-2014 05:48 PM
โJul-21-2014 05:39 PM
โJul-21-2014 03:51 PM
