Aug-16-2019 09:49 AM
Aug-18-2019 05:56 AM
Aug-17-2019 06:47 PM
drsteve wrote:WayneAt63044 wrote:
Window units (also in homes) need to tilt to the outside so that they drain outside. It should drain outside if the drain is not clogged, the unit is tipped to the outside, and the condensate pan is not cracked or leaking. I'll bet you can fix it. Good luck!
Newer window unit do not have a drain. They use the fan to sling water on the condenser coils for increased efficiency.
Aug-17-2019 09:57 AM
Aug-16-2019 06:44 PM
Aug-16-2019 01:50 PM
Aug-16-2019 12:11 PM
