water pump upgrade 2005 Bigfoot
GULFMAN
I was thinking about up grading my original water pump. It is in a 2005 Bigfoot TC.
Does anyone have any recommendations?
Thanks
21 REPLIES 21
Reddog1
GULFMAN wrote:
The noise is not the problem hearing it run is just fine.
Its the pump turning on and off all the time when running the water.
At nite i just turn the pump switch off and when we are outside just in case there is a leak.
I typically turn my pump off when I leave my TC. With the accumulator, I will have two or three quarts of water with the pump off.
I too have the Surflo Whisper pump. The name does not describe the pump as bigfoorford stated. The accumulator does not make the pumps quieter, it only reduces the frequency of times the pump turns on. When someone uses the toilet at night, the pump seldom comes on waking others up.
You can install the accumulator in any position. My preference is to mount the accumulator with the inlet pointing down. This allows you to completely drain the tank. It is important to have correct air pressure in the accumulator, and the pump. If incorrect, the amount of water held in the tank typically will be incorrect. I think there this is detail in the link bigfootford posted.
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
bigfootford
Nomad II
Nomad II
GULFMAN wrote:
bigfootford
THANK YOU very much for the reply!!
Our last trip is thanksgiving for the year so i winterize for winter with rv antifreeze is that expansion tank going to change the way i do that.
Only thing I would do is mount the tank Vertically so you can drain it.
I do not winterize mine... I keep a small 750 watt electric heater set for 50deg... I do not like my camper to get cold and then damp. We rarely get below freezing here in Sacramento anyway.
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Bilstein shocks, air bags/pump, EU2000, PD 9260, Two Redodo 100ah Mini's, Aims 2500 Conv/Inv, 200W. solar, Morningstar Sunsaver 15A/ display panel, Delorme/laptop for travel, Wave-3 heat.
GULFMAN
2oldman
egarant wrote:
I can't even hear my pump anymore.
I like to hear my pump a little in case there's a leak.
GULFMAN
bigfootford
bigfootford
Nomad II
Nomad II
GULFMAN wrote:
bigfootford,
Is your water pump located under the table floor by the table leg?
If so did tank fit down in there beside the pump?
Did you keep the original pump?
Not for sure what pump i have but will look.
Thanks all for the reply's
My BF is a 2500 9'6".
My pump is in the compartment under the rear dinette seat wall that is against the bathroom and is . covered by 1/8 plywood.
In the compartment is the hot water tank too, along with it's plumbing and the winterizing plumbing.
I installed the Accumulator Tank on it's side... in that compartment against the hot water tank.
Prior to the accumulator tank install I replaced the OEM water pump because it was so noisy. I installed the Surflo Whisper pump... hahahaaa It was almost as noisy as the OEM... Plumbing tubing actually makes all the noise.
So I liked how Reddog1's Accumulator tank worked along with other local Rv.net folks so I installed the tank...
I can run about 1.5 quarts before the pump turns on...
Sorry, I have no pictures.
Jim
egarant
The two items towpro mentioned, the Shurflo pump and accumulator AND the Shurflo Pump Silencer Kit is all you need.
2021 FORD F350 dually 4x4 with 4.30 gears, 013 Eagle Cap 950, 480 Watts Solar, 3K Victron Multiplus II, Victron smart DC-DC charger, Victron 100/30 solar controller, 250 amps of lithium batteries by LifeBlue
GULFMAN
bigfootford,
2oldman
Old-Biscuit wrote:
Reason I wouldn't buy one NOW is Shurflo DISCONTINUED that model several years ago and any pump or pars for that pump are OLD STOCK sitting around on shelves for couple years
would have been nice for Amazon to post that.
Reddog1
towpro wrote:
for the pickup camper, I was thinking of something a little smaller like this.
Too small and too pricey. You need to look at the forum link posted by bigfootford. It is important to understand, the larger the accumulator, the less often the pump kicks on, and the longer the pump runs to fill the accumulator. The one in your link is minimal in my opinion, looks cute, but not large enough to be worthwhile to install.
Wayne
Toad: 91 Zuke
Old-Biscuit
2oldman wrote:
Don't get this one.
Sounds like a sick cow.
I wouldn't buy that one either (Shurflo 2088) not because it's a bad pump-----pump in my 5th wheel is a 2088 and still runs great after 10 yrs.
Reason I wouldn't buy one NOW is Shurflo DISCONTINUED that model several years ago and any pump or pars for that pump are OLD STOCK sitting around on shelves for couple years.
Good replacement is the Shurflo 4008 as in 'towpro' link.
Shouldn't need an accumulator tank as it has an internal bypass to control low flow cycling.
GoinThisAway
Sorry, I can't help you. I like hearing the water pump as with every burp its telling me to go easy on the water :B
2008 Dodge 3500 DRW 4x4
2008 Bigfoot 25C10.4
Torklift/Fastguns/Hellwig/StableLoads
jimh406
towpro, that looks helpful and easier to mount. Thanks!
towpro
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
