Weighed truck
RWDIII
before I Took the camper off the truck,decided to get it weighed at the local truck stop before and after.
Was surprised that all the weight was on the rear wheels,thought some would be on the front.Weight is with me in the truck,200 lbs.
Empty 6980
steer axle 4100
drive axle 2880
Loaded with camper 8860
steer axle 4080
drive axle 4780
With my camper the COG is on top of rear axle
OLD 2006 F150 4wd 7200gvw,Lt275-65-18,Scan Guage,Garmin,flowmaster,load levelers,Firestone work rites Bronco 800
NEW 2015 F250 Scab 4wd 10000 gvw, 6.2 Scan guage,Garmin,work rites,3200 lb load,1800lb Palomino Backpack SS1200
11 REPLIES 11
Bedlam
Moderator
Moderator
HMS Beagle wrote:
I'm surprised the truck is that light. My 2015 supercab F350 is just a couple pounds shy of 8000 with the fuel tank full. Diesel dually though.
My 2005 F250 SC SB with PSD was 4500 lbs front and 2750 lbs rear (scale would fluctuate between 2740 and 2760) without tailgate, me or anything in the truck. The 2015 weights sound about right for a gasser.
Kayteg1
wvabeer wrote:
I would have thought those campers would be lighter.
You must be listening too much to F150 salesmen?
wvabeer
1999 Dutch Star DP3884
2015 Camplite 6.8C
2012 Cherokee 39L destination
2022 F350 XL 4x4
07 FLHRS
Kayteg1
"Being unique" is the main rule in this sport, isn't it ? ๐Ÿ˜„
boogie_4wheel
Kayteg1 wrote:
Actually looks like it is slightly behind the axle as the camper took 20 lb from front axle.
Now when your short and light camper do real trick to rear axle weight, think what mine does.
Your truck is hurting my brain. 2nd Gen Dodge bed. What is going on?
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
Kayteg1
HMS Beagle wrote:
Kayteg, it doesn't look like you have that humongous thing all the way forward in the bed?
No, I have 12" space behind the cabin. Whole set started with cab-over resting on my roof lights what moving the camper back solved to some degree. Even with light covers removed and 1/2" shims on the bed I have minimal clearance.
Than I found I really enjoy the extra cargo space behind the cabin and having beefed up suspension on dually, I don't have to worry about too much weight on the rear. Still have yet to make trip with the camper to scales, but my rear empty is like 3300 lb, while the 4 tires give me about 12,000lb capacity.
RWDIII
RWDIII wrote:
Old-Biscuit wrote:
So camper was EMPTY.......1880# loaded except for food,drinks
Doesn't leave much in available payload? rear axle 6290lbs
How much is sticking out past tailgate?
removed tailgate 16 inches past bed,8inches past bumper
My camping weight is about 9k
1k under 10 k rating
Just thought some weight would be on front:h
RWDIII
16 inches
HMS_Beagle
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
Old-Biscuit
Kayteg1
