Weight Sticker Math Exercise
Vic_R
Hi all – I’m trying to make sense of all of the weight data that I have:
1 – Cat Scale Weight w/ Camper on – 10920
2 - Cargo Weight Rating Sheet – 2802
3 - GVWR (door sticker) - 11700
4 - Tire and loading (door sticker) occupants and cargo should not exceed 3668
So if I subtract the tire and loading sticker (3668) from the GVWR (11700), that means the curb weight of the truck is 8032. That seems about right on other ratings sheets I’ve seen for a diesel 4x4 crew cab so I’ll go with it. I’m assuming this is with a full tank of diesel & DEF too.
If I subtract the Cargo weight rating sheet (2802) from the occupants and cargo sticker (3668), that means they assume 5 passengers (console & bucket seats, no front bench) must weigh 866 or 173.2 each (I won’t tell my wife what Ram thinks she weighs..)
And then the final calculation, and reason I started this whole exercise, if the truck has a curb weight of 8032 and I subtract my loaded scale weight of 10920, the loaded camper is a hefty 2888 (full water tank & LP tank and truck had a full diesel and DEF tank, but no driver)
*Note this isn’t a perfect analysis because I had the tailgate off for the Cat Scale weight but I’m sure its incl in the curb weight. So the camper is probably another 50 lbs or so. Also not sure if driver is part of the curb weight but assuming no?
Did I miss anything?
Hallmark Everest pop-up truck camper on a 2014 Ram 3500 Cummins Turbo Diesel, 4wd, Aisin Auto, crew cab, short bed
21 REPLIES 21
Buzzcut1
Nomad II
Nomad II
this is the certified road weight of my 2011 F350 Dually: 6.7L diesel 4x4, Crew Cab Long bed
With a Lance 1055 fully loaded with gear Water and Propane
So yeah the trucks and TCs can be heavy
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Steve_in_29
jmtandem wrote:
According to the bill of lading when they shipped my 2007 F350 SRW, Extended cab, 4x4, diesel, down to CA from CO it's weight was just under 8000.
Steve,
What does your Outfitter weigh?
I have never gotten it weighed but from what another Outfitter owner posted about his slightly less equipped camper I think I'm a bit above 3000lbs.
Which puts me near or at the GVWR of 11400lbs on my truck. I do know that when fully loaded for a trip my truck still sits slightly tail high and that is on a stock suspension with no add-ons.
To be clear the truck was being shipped from one Ford dealer to another as part of my purchase of it and it had nothing to do with Outfitter.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
jmtandem
Steve,
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
Steve_in_29
Jfet wrote:
I didn't realize a 4x4 pickup truck could be 8000 pounds curb weight. Wow. I thought a gasser is more like 5500 and diesel 6500 or thereabouts.
Are we talking F550 or something?
jmtandem
Hi Vic,
I guess I am Johnny Come Lately on this interesting weight issue. I looked up your truck (2014, 11,700 gross, Cummins, Aisin, 6.4 bed, crew, and 4x4) in the 2014 Ram brochure. Your payload is 3950 (page 37 of the brocure) that puts your truck around 7750 pounds empty. That is about what my Ram weighs empty, also. I think the Aisin is heavier than the manual or the 68RE. As to the tailgate weight credit when off, I consider that a 'wash' since I have permanent Tork Lift camper tie downs (so do you). They probably weigh approximately the same as the tailgate. For weights water is 8.3 pounds per gallon, propane 4.2, and diesel 7.1. It is easy to have more than 300 pounds difference in weights just with how much diesel and water you are carrying at a given time. As to the previous comments about being under 80 percent of gross, that is almost impossible for most carrying a truck camper. In fact, looking at your numbers it is good that you opted for a one ton as the 2500 Ram (Cummins, 6.4 box, crew, 4x4, auto) maximum payload is 2250 pounds, more than 1600 pounds less.
Based on the sticker of 3668 pounds, you have about 280 pounds of options, accessories or stuff in the truck (3950-3668) So your truck weight is probably with full fuel (210 pounds +/-) about what you calculated. Pop up truck campers sure have gotten heavier from the days I owned an Alaskan camper.
bjbear
********** I did actually get the weight by axle. It was (f)4920/ (r)6000 and my door sticker said not to exceed 6000/7000, so I'm good there
Vic R - You cannot determine the curb weight of your truck from the information you have. Also, you cannot determine the camper weight either. Although they are related to some degree, there is no direct relationship between GVWR, axle weights and rated payload.
The only way to get these weights is to weigh your truck with the camper off and then compare that to your weights above.
I always find that there is a lot of misunderstanding and misinformation around weights and ratings
Front Axle - Your GAWR(front) is 6000 and your actual is 4920 so you are well under. IMO it is not a good idea to exceed GAWR.
Rear Axle - Your GAWR(rear) is 7000 and your actual is 6000 so you are well under here too. You can safely add 1000 lbs of gear.
COG - This was mentioned as being important which is true. In your case however, I would say that your COG is well within limits because if you look at the GAWRs, the ration of front to total is 46%. Your actual ratio is 45% which is good. If the COG is too far back, it will take weight off the front axle and put it on the rear. This can affect the handling and braking ability. This is where the payload rating comes in. If you overload the rear, it will change this ratio. Again though, you are just fine.
Tire Rating - Your tires are rated at 3668 which doubled is 7336 per axle. You are good on both the front and rear. Tires are another rating that you should never exceed. Also, the age of your tires is important as someone already mentioned. As tire age, they are prone to delamination and cracking. However, this to some degree is factored into the rating.
GVWR - Your rating is 11700 and your actual is 10920. You are well under your GVWR and have 780 lbs of additional capacity. However, unlike axle or tire ratings, there is a lot of "fat" in the GVWR ratings as it covers so many different components (transmission, brakes, driveline components, cooling, etc. etc.) In my opinion and that of many others, it is acceptable to exceed the GVWR by some margin. My limit is 10%, but others have exceeded it successfully by much larger margins. This is something you need to decide for yourself and it depends a lot on where and under what conditions you will be driving. For example, if you are driving a lot of steep mountain roads in hot weather, you may want to stick to the GVWR, but if you are mainly on regular highways in normal temperatures, then going over is acceptable IMO.
The suggestion that you should stay below 80% of GVWR has no valid engineering basis. Might be a reasonable suggestion as it would definitely extend the lifespan of your truck to some degree, but as also mentioned, given the wieghts of TCs and the capacity of trucks that most of us can afford, this is just not practical and definitely not necessary.
You cannot subtract the weight of your wheels and tires from the ratings. This is often asked, but this is already taken into account when they set the ratings.
So the bottom line here is that you have a really great rig that you can be totally confident in driving down the road. You have some surplus capacity to carry more stuff without having to worry about it. And no, you are not over thinking this. Safety of yourself, your family and the rest of us on the road is important so it is great that you are asking the questions and trying to educate yourself so you can make the right decisions. Now go out and enjoy your rig!! :B
2006 Monaco Camelot 42-DSQ
09 Blazer 20' Covered Trailer
Toad - 2019 Wrangler JL Rubicon Unlimited
My Website
Vic_R
jimh425 wrote:
Vic R wrote:
And by the way - here is the rig itself.
Nice looking rig. I'd also look at the COG for the camper as well. Is that a 5 1/2 ft bed?
No its the 6' 4" *regular short bed*. COG has been on my mind and I need to exercise self control on those two work boxes on the back. It would be very easy to load those up with heavy stuff and move the COG too far back. Will likely move the spare up to the front to offset a bit, as that also solves the access problem should I ever need to change a flat.
yosemiteford
Don't forget to consider the age and current mileage on your tires - how many miles will most of you go on a set?
2009 SRW FX4 F350, 2002 Lance 1010,TL Stableload, Solar, mini-table, solar, airbags. front Reese hitch, Michelin LTX A/T2, propane generator, Carefree awning,Rigid Off Road Lights
jimh406
zb39
covered wagon wrote:
Can't the weight of the wheels, tires, and axles be subtracted from the total scale weight? After all they rest on the road not on the truck.
Got to be about 700 lbs. credit right there, right? Wrong?
No.
2017 Host mammoth, sold
49 states, 41 National Parks, 7 Provinces
2019 2 door Rubicon 6 spd.
2019 Berkshire XLT 45B
2022 Host Cascade
2021 Ram 5500 Air ride
Vic_R
Thanks All - I did actually get the weight by axle. It was (f)4920/ (r)6000 and my door sticker said not to exceed 6000/7000, so I'm good there.
Less than 80% GVWR would be tough - I bet when I get it loaded with gear and wife and kid we'll be pretty close to the 11,700 rating. I suppose I don't have to travel with a full water tank and I probably won't if I tow anything with any sort of tongue weight.
As far as overthinking...its what I do 🙂
covered_wagon
Reddog1
Trucks haven't been that light in years. I had a '96 1500 Dodge that weighed 5,300. My '07 Chevy diesel was a regular cab with no options and weighted 6,800 pounds empty.
My '05 Chevy dually crew cab is about 8,000. We just got a new 2015 Chevy 3500 at work with a utility body and ladder rack. It's about 9,000 with nothing in the bed....
I have a 2004 Dodge Ram DSL 3500 DRW 4x4 Quad Cab, with the tow package. I have not weighed it yet, but the book says: CURB WEIGHT 7380 pounds.
I have weighed my 1996 Dodge Ram DSL 2500 2WD Extended Cab. It is 6200 pounds.
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
rtk2
I think the original poster did it perfectly and his analysis is correct.
