โJan-11-2018 06:15 PM
โJan-19-2018 02:35 PM
kc8yhk wrote:Cummins12V98 wrote:transamz9 wrote:Cummins12V98 wrote:
^^^^^ Incredible Fish! ^^^^^ There are idiots born every day that have knee jerk responses to everything.
Idiot? Really?
I think I said "IDIOTS".
Well that's not very nice.
โJan-19-2018 11:49 AM
Idiot? Really?
โJan-18-2018 06:24 AM
Idiot? Really?
โJan-18-2018 02:19 AM
โJan-18-2018 02:08 AM
โJan-17-2018 07:17 AM
โJan-17-2018 06:46 AM
larry barnhart wrote:
if you follow the story on the link above this couple seems to have a problem for whatever they buy.
chevman
โJan-17-2018 06:43 AM
โJan-17-2018 06:42 AM
โJan-17-2018 05:25 AM
โJan-16-2018 07:45 PM
transamz9 wrote:FishOnOne wrote:transamz9 wrote:FishOnOne wrote:Cummins12V98 wrote:
Heck even my 98's WIF sensor went off when it had a 1/4 teaspoon of water in the filter housing. It was left over from the 30 gallons of water I pumped into my truck one morning. :M
So water get's into the fuel and then there is rust??? What the heck from???
I'm not talking about the old fuel systems. Even a 7.3PSD can engulf sand and water and not phase the injectors.
Think about the precision that the injectors have to be machined to hold 20k+ psi of fuel pressure on them without leaking, and then think about these precision surfaces with just a flake of rust that prevents them from seating properly. It doesn't take much and is the reason Ram went with a dual filter system like Ford.
A true water separator won't let water through. I never understood people saying the dealer told them rust was in the system. IDK, could be but not likely. My thoughts are that the filter stops the water and fuel to the pump. The pump that GM and Ford uses grenades when starved.
I still haven't really figured out why the V8s are having to run such high fuel pressures to make the same power as the 6. It takes so much fuel to make so much power. maybe someone could school me on this? I would think the volume of fuel it can put out at the required pressure would be the thing.
6.0 injectors are the same way. Run a 6.0 out of fuel and you just as well order some injectors.
It has nothing to do with a V8. Diesel fuel is difficult to atomize and atomized fuel burns cleaner with less soot and less soot means a more reliable emissions system. Hence the reason for the increase fuel injection pressure.
The 2.8 I4 Duramax in the Colorado runs 29k psi and its a inline engine.
More reliable emission system or more reliable injection system..........hhmmmm I'll take the injection system Jim! lol
โJan-16-2018 06:28 PM
โJan-16-2018 06:22 PM
spoon059 wrote:
Since we are so off topic, can I use this as a moment to ask why select people insist on quoting a quote of a quote of a quote of a quote of a quote of a quote of a quote instead of just replying and not taking up so much screen space?
Just curious if there is a reason...
โJan-16-2018 06:02 PM
โJan-16-2018 05:12 PM
goducks10 wrote:.hone eagle wrote:Huntindog wrote:FishOnOne wrote:The Ford fanboys love to poke fun at the GM DEFtransamz9 wrote:mich800 wrote:fj12ryder wrote:
I'm brand loyal when the brand I buy doesn't fail. That's how a company makes me want to buy another one.
Treating me decently when a known problem rears its ugly head, rather than fixing said problem before I have to deal with it doesn't make me brand loyal, it makes me look for alternatives. I have no real favorites when it comes to trucks, I own a Ford and a Dodge.
Might want to take up walking as they all have known failure points.
When a company has had problems with a part that causes such devastating and expensive problems for 7 years and the customers are worried and not sure if the company will back their product is crazy. If I was scared that Ram was not going to back my truck I would be shopping right now for another brand. I definitely would not buy from them again and I definitely would not step down in capabilities to stay with them. People can make fun of my recalls but at least I don't have to worry if they are going to back their product.
Then I hope you don't have to deal with fuel contamination because Ram, GM and Ford techs all look for signs of contamination before any warranty work is approved plain and simple. If your fuel system gets a taste of water, rust will follow and a complete fuel system is in your cards.
As for the problems they're not widespread like you and others portray and most people don't live in fear including myself.
fill location. (under the hood) But I have NEVER read of an account where a GM owner mistakenly put DEF in the diesel tank... Perhaps GM knows a thing or two about the likely hood of people making a mistake.
I do not know about the Rams, but the Ford forums have had MANY reports from people that did just that.
Is that why GM moved it for the next model?
x2
