โFeb-26-2018 12:04 PM
โMar-02-2018 05:27 AM
โFeb-27-2018 06:54 PM
โFeb-27-2018 06:35 PM
โFeb-27-2018 04:29 PM
โFeb-27-2018 11:38 AM
PenMan wrote:
I went from a 23 foot to a 37 foot TT. I pull with the RAM in my signature. Total length is 59 feet. It is actually easier to back the longer trailer but as others have mentioned the road width is fairly important when trying to back into a space. As far as pulling on the road I can barely tell the trailer is back there until it's time to stop. It is a much heavier trailer and does take longer to stop. It all comes down to practice and knowing what your setup can handle.
โFeb-27-2018 10:03 AM
โFeb-27-2018 07:33 AM
โFeb-27-2018 06:44 AM
ktmrfs wrote:
My trailer is over 35ft long with the extended rack on the back. with the TV and bicycles on the back I'm 65ft overall. Towing with a denali cc sb and a reese DC hitch.
as far as towing, piece of cake. It's the "other things" that one must watch out for,
1) can I fit into and get into a campsite and can I get around the campground road? If in doubt I call and in every case able to answer my questions. In a few cases the response was "when you arrive, let us know and we will block traffic so you can go wrong way on the road to get into the site best"
2) This big a trailer does pose problems in some older campgrounds FS, State park, CCC, etc. Often we find only a fraction of the sites will really accomidate us. In older campgrounds it's often the road width, not campground pad that can be an issue backing in. And in some places older FS campgrounds are off limits. Bummer since we like dry camping in rustic locations. This is seldom an issue in RV parks. However in all our travels, roughly 3 months/year we have yet to not be able to camp near our intended destination. Just need to make sure the campground can handle us.
3) We plan on using truck stops for fuel. usually means reasonably easy to get in and out
4) We are careful how we go through small towns. right angle turns on two lane roads usually means needing to swing into an oncoming traffic lane. Even worse with cars parked. If it's two traffic lanes both ways, I try to at least partially hog the other lane to make a turn, like truckers do.
None of this is serious enough for us to consider a smaller trailer.
Oh, and an advantage is at least for me, I can back the 35ft trailer into a narrow spot quicker and easier than I can back my 14ft cargo trailer into the same spot.
โFeb-27-2018 12:11 AM
SDcampowneroperator wrote:
Towing a TT is different than a 5er. TTs are buffeted more with side winds and passing big rigs.
In fuel stations , camps, turning in traffic, TTs are easier than a 5th due to axle to axle ratio and turning pivot behind the bumper rather than over rear axle .
Simply put, turning radius is determined by the value of the axle to axle distance given that the front pivot point is static as in a 5th whl. When the pivot point is turned outside the arc of the turn as in the case of TTs, the tongue swings outside the arc to advantage,enabling quicker turns.
In my experience, a 34' tt turning radius would equate to a 26-28' 5 th given the tow has an 8' box due to axle setback on a 5er.
โFeb-26-2018 06:57 PM
โFeb-26-2018 04:35 PM
โFeb-26-2018 04:28 PM
โFeb-26-2018 04:16 PM
โFeb-26-2018 03:45 PM
