Apr-10-2022 10:17 AM
Apr-11-2022 05:56 AM
Apr-10-2022 07:06 PM
Apr-10-2022 05:53 PM
larry cad wrote:JRscooby wrote:
Can I expand a little?
What about the roof? Will it handle the weight of you and the AC concentrated in the small area of your feet?
I used a couple of pieces of Styrofoam, set AC on to slide from side to hole. Step ladder in back of pickup to get it on roof, with line around it. Up another step ladder to pull across near hole. Then a stepstool inside to lift and guide it into the hole.
Another idea. To me, holding the inside part up, aligning and starting the longdonkey bolts was a PITA. Cut 2 pieces of all-thread little longer than bolts, screwed into holes. But the plate up, EZ to guide AT thru holes, start nuts. Then nuts hold in place while you start the bolts in other holes. Double-nut the all-thread to remove, last 2 bolts.
Typically the roof will support you and the AC as it has to support the A/C all the time anyway.
I've personally changed out several A/C units and have never needed any allthread to do it. Bolts went in easy. If not, the A/C is not located correctly.
Apr-10-2022 05:24 PM
Apr-10-2022 05:10 PM
Apr-10-2022 04:56 PM
Skibane wrote:whatinZamzoo wrote:
A average sized women would be on it & I would be pulling from the top.
This plan has "disaster" written all over it.
Apr-10-2022 04:49 PM
Apr-10-2022 03:52 PM
Apr-10-2022 03:45 PM
Apr-10-2022 02:31 PM
Apr-10-2022 01:53 PM
Apr-10-2022 12:33 PM
Apr-10-2022 12:16 PM
Apr-10-2022 11:52 AM
