Where can I buy hinges that hold the cabinet doors open?
hedgehopper
The hinged doors on the cabinets next to our cabover bed do not stay open by themselves. (The cabinet doors are in a horizontal plane when closed and in a vertical plane when open.) Where can I buy hinges that will hold the doors open? We have a 2002 Northern Lite 10-2 CD.
13 REPLIES 13
in5r
Rockler.com has many different cabinet hardware items that may fit your needs.
2019 Ford F250 6.7 CC SB
2015 Jayco Eagle HT 28.5RSTS
NEOK
Look on eBay for the metal spring supports. I found several on there when I replaced one of mine.
neok
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
K_Mac
I got mine at CW , an exact match to what NL put in my 13" 10-2. Look at the ones in the kitchen area cabinets, that size worked fine for mine.
hedgehopper
markchengr,
That sounds like it might be what I'm looking for. But the link doesn't work. Could you recheck it please?
markchengr
I used these. They're the same as the ones Northern Lite uses on their overhead cabinets. They work great and you only need one for each door. Don't know why they didn't put them on there in the first place. -Mark.
http://www.rvdiscountsuppliers.com/hardware/cabinet-door-supports/cabinetdoor-spring-support-rv-camper-trailer-parts.html
Reddog1
I have seen a simple spring used. One screw in each end for mounting. Mounts like the Camping World support. Because it is a spring, when the door is open, you simply push the center area of the spring in and it closes the door. The springs are about 3/8" to 1/2" in outside diameter. The come in different lengths and available at most hardware stores.
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
bcbouy
try craigslist.there's always someone scrapping a camper for parts.
2012 ram 2500 hemi crew cab sb 4x4 2015 northstar 850 sc 14.5 g3 guide custom fly fishing boat
Golden_HVAC
http://www.liftsupportsdepot.com/
They have a very large selection of lifts. Yes even small ones and ones for my tailgate on a Dodge caravan.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
Tripalot
Camping World also carries some. We have to replace one on a cabinet over our kitchen sink. Check the length and the pressure carefully. The C.W. we were in did not have exactly what we needed so we are hopeful another location will. Cost was about $20.
2014 Triple E Regency GT24MB (Murphy Bed) with all the good stuff
towing a 2016 Jeep Cherokee TrailHawk
Berkley, the amazing camping cat missed dearly (1996-2012)
Geewizard
This is what I use. They work very well for me.
Metal Spring Loaded Cabinet Door Support
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
deltabravo
AnEv942 wrote:
possibly some spring load assists?
http://www.campingworld.com/shopping/item/plastic-spring-loaded-cabinet-door-support/49542
Sounds like the same cabinets that my AF811 has - the cabinets on the floor of the cabover, on each side of the mattress.
The product above is what's used on my camper.
AnEv942
Overhead doors, possibly some spring load assists?
Usually about $6
Bing images
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
Grandpere
I would start my search at Lowe's or Home Depot. If they do not have them they might be able to steer you to someone who does have them.
Berniece & Russell Johnson
Lil'Bit, a Netherland Dwarf Rabbit
1987 Southwind
1995 Ford F150 Supercab
Life in the fast lane? No thanks, we will stop and smell the flowers at every opportuity
