Jul-10-2019 01:01 PM
Dec-18-2020 08:40 AM
Sliding-into-home wrote:
Good info. Very curious if you log much snow/ice driving on them. Could be a good option for a steer tire at the very least.
I just put my Nokian Hakka LTs back on for the 3rd season. Still not showing any signs of wear. Still like velcro. They've thrown a few studs though. Only problem is they're only rated for 3600-ish lbs. To my knowledge there isn't a 19.5" Nokian 3pmsf tire, but if anyone else knows otherwise, let me know!
Dec-18-2020 07:32 AM
Grit dog wrote:
You can get studdable 19.5s and have them siped.
They would make good snow/ice tires then, although not as good as the Hakkas as they’ll be nowhere as soft.
Old saying cheap fast or good, pick 2 applies here. Except it’s traction, load rating or ride, pick 2.
Dec-17-2020 10:54 AM
Dec-17-2020 07:02 AM
Dec-17-2020 06:26 AM
Dec-17-2020 05:50 AM
Earthroamer82 wrote:
Good morning Reality Check,
Did you ever get the M655s installed? How are they handeling?
Thanks, Charlie
Dec-16-2020 06:31 AM
Dec-01-2020 03:08 PM
jimh425 wrote:
Reality Check, can’t wait to hear what you think about the M655s.
Are they going on the front as well? Are you putting 225s on? I know 225s are recommended for stock rims, but I keep reading that some put on 245s with no issues. No idea if they carry any weight on the F450s that run 245s..
Dec-01-2020 07:38 AM
Dec-01-2020 05:56 AM
Has anyone tried the new Toyo M655? Looks promissing.
Dec-01-2020 04:49 AM
Dec-01-2020 04:35 AM
jimh425 wrote:
there are 18s now that approach the load rating of 19.5s at 4080 lbs for the 18s. That might be worth a consideration.
If you aren’t maxing out the pressure on the 19.5s, you could end up being equal with no ability to air down when the TC isn’t on the truck much past 70. You’ll pop the bead on a 19.5 if you air down. Also, the speed rating is much less on most 19.5s.
Nov-30-2020 05:36 PM
Nov-30-2020 04:03 PM
Nov-30-2020 12:23 PM
