โApr-20-2017 09:29 AM
โJun-09-2017 02:05 PM
towpro wrote:
BillyRay, Where did you go with this one? Did you end up with the upper stable loads installed? how is the difference?
I am still on the fence, but with my 990 loaded, I am just hitting the overload springs. I think bringing the Over Load's into play will help with what little sway I do have.
I have a set of the Progressive Suspension blocks showing up tomorrow.
โJun-08-2017 12:06 PM
โMay-01-2017 07:29 AM
HMS Beagle wrote:Grit dog wrote:
When you load your truck and the weight engages the entire lower spring pack(bottom leaf) and the overload leafs, the spring rate is much greater and there's a lot less side to side body roll.
If you load the truck down then pump the airbags back up to get it back level or close to unloaded height, you're not using all the springs. Air bags will hold the load up but for a high CoG load like a TC, the nature of the air bags is they'll have some flex in them.
If you achieve the same ride height, any weight not being carried by the springs is being carried by the airbags. The airbags likely have a higher spring rate than the overloads, and certainly more progressive. Like many things, the devil is the details. My truck has less body roll with full air suspension than it did on the springs.
But an antiroll bar is really the tool to solve body roll.
โMay-01-2017 07:09 AM
โMay-01-2017 05:40 AM
โMay-01-2017 05:08 AM
Area13 wrote:
Same camper, different animal hauling. I absolutely love the Firestone airbags with compressor. I always end up with more air in the left one. I'm petty sure the camper is left heavy (slide side). I just make sure I keep in good contact with my upper stable loads or I start to sway. When I tow my boat this summer, it's going to be nice to compensate for the tongue weight too.
โMay-01-2017 03:39 AM
โApr-30-2017 06:50 PM
โApr-30-2017 10:39 AM
โApr-30-2017 09:00 AM
thedavidzoo wrote:
billyray, didn't you give up on the upper Stableloads before and get your money back? The install on newer Rams is a PITA, as we both have confirmed...
โApr-30-2017 08:29 AM
OneTrack wrote:
This is very interesting. I also have 2015 RAM DRW truck, and have been looking at airbags too. Same reason; just to raise the rear to normal 'loaded' level when 'max loaded'. Then the truck is level front to rear, and the headlights aren't pointing skyward, the camper is level, etc.
Curious why some think stableloads are a better way to achieve this over air bags.
โApr-30-2017 07:58 AM
โApr-30-2017 07:25 AM
โApr-29-2017 05:33 PM
