Yes, there is a "magic formula" and it is:
GCWR >=
actual weights of
TV + Trailer + stuff
But...gotta decide if you believe in your OEM's rating/specification system or not....and are willing to both go out and actually weigh your TV/Trailer/Stuff or use their max ratings as the basis to do the simple math
Actual tongue weight is VERY subjective. Even if taking two setups with the exact same TV & trailer. Folks load up differently and even the folks weigh in differently...the why of the formula above and weighing everything (or knowing their actual weights...or using the max weight ratings...GVWR of both TV & trailer, etc)
Also, above assumes stock. If you have modified, then your re-engineering must take that into account...luck that most OEMs have such a high margin designed in today, that many can overload and not notice...they just reduced their setups performance and longevity
You will also need to know your OEMs (both TV and Trailer) ratings:
GVWR
GAWR (front and rear)
GCWR
MTWR (max trailer weight rating) is only applicable if you own a curb or stripper model, one 150LB driver and pretty much nothing else loaded onto/into the TV
Diff ratio, but with today's close ratio (more gears) and Tow/Haul button, generally a moot discussion
macminn wrote:
The towing capacity of my suburban says 6,000 lbs. Is there a magic formula I should stay under as far as trailer? I've been told to stay around 5,000. We really like one that's 5,400.
-Ben
Picture of my rig1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
