Who checks their oil?
Grit_dog
Navigator
Navigator
After doing an oil change?
Do ya dump in the reccomended amount of oil, put the cap on, slam the hood down and takeoff?
Or do you check to make sure it reads right on the dipschtick?
95 REPLIES 95
Grit_dog
Navigator
Navigator
Wild Bill 888 wrote:
Yep, I check.
But I leave it about a quart low and then add a quart after a thousand miles or so to refresh the additives.
That's a new one.
Grit_dog
Navigator
Navigator
fj12ryder wrote:
Who doesn't?
Apparently only me...lol. I mean I do it form time to time, but it takes what it takes.
I do like the leave it a qt low idear to see if it's making oil or not, but I don't have a 6leaker so that hasn't been a big concern of mine.
BarabooBob
I was planning on putting a pit in my garage floor when I built my garage. The inspector informed me that if I did put one in, he would make me fill it in and then would inspect my garage every year to make sure it was not dug out again. He has stopped to see if I cut the concrete to install the pit. I greatly dislike that man.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
2Rad4U
Bedlam wrote:
I dump in the specified amount of oil, run the engine for about 2 minutes to fill any voids while looking for leaks, check the level with the dipstick and add any extra amount required. I check oil level at each fill up unless the truck is sitting on a slope.
My routine as well
Chris
2005 Rockwood 2516G (sold)
2005 Max-Lite 24RS (sold)
2019 Rockwood 2608BS (sold)
2020 Grand Design 337RLS
2018 Chevy 2500HD
Wild_Bill_888
Yep, I check.
bpounds
On my truck specifically, I check the oil level BEFORE I drain the oil. If it isn't where I left it, I would know something was wrong.
I also check it after filling, giving it time to drain down from the heads, but before running the engine. The dipstick won't show accurate for a long time after running.
The book calls for 15qts. I only run 14. I want the oil level to be in the center area of the crosshatch marks. If it makes oil, I want to be able to see that. It doesn't use any oil, and it doesn't make any, so far. Occasional oil lab tests keeps me verified and in the loop.
I will admit to becoming complacent about checking oil level between changes. Something about checking time after time after time, for years, and never needing to add any, makes me complacent. I'm more likely to just look underneath on the concrete every day to make sure there aren't any drips.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
p220sigman
I always check it following an oil change and then again after it has been driven for a day or so. Also checking for leaks as well. A minute of time is worth it if I find something amiss with the oil level.
Grit_dog
Navigator
Navigator
Lynnmor wrote:
I have a pit in one garage bay, so changing oil is easy. When I have a few changes in my oil waste collector, I take it to an Amish farm where they burn it to heat the barn.
Nice! I'd LOVE to have a grease pit or a lift....not picky.
Grit_dog
Navigator
Navigator
fj12ryder wrote:
Who doesn't?
Unless I'm not sure of the capacity I don't. If it takes 7qts on time, it takes 7qts every time.
Lynnmor
I have had my oil changed by others one time in my life, that was a free change by the dealer. Well when I got home the dipstick was way over full, the idiots put in too much oil. Took it back and they still got it wrong. Never again!
I do check the oil after I change it, but on my 6.7 Ford diesel the cable type dipstick is about useless till it sits for a day. Then I get one chance to check it because the cable drags oil up the tube and subsequent checks are again useless.
Grit_dog
Navigator
Navigator
ScottG wrote:
Many years ago I forgot to put the drain plug back in a vehicle. Thankfully I checked the oil before starting.
That taught me to always check.
It wasn't too many years ago I did the same. Well only put a wrench to one of the 2 drain plugs (bike). That quart of oil came out at about 11,000rpms in 3rd gear uphill. Wish it had drained out in the trailer! No more multitasking while doing oil changes!
Campinfan
salem wrote:
You've probably all heard about the guy who went into the auto parts store and asked for a new dipstick. Said his old one didn't reach the oil anymore.:S
thats about as bad as the guy who went to the auto parts store and when asked what he was looking for he said, "how about a new gas cap for my Yugo....the worker replied "sounds like a fair trade to me"
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
Campinfan
I pour my used oil on the ground...I figure if it came from there, it should be ok to go back. (I am just kidding) I take it to the recycle area when I get some, but I do not change my oil myself too much because it is much easier for the dealer to rotate the tires and stuff.
IdaD
In our area used oil is picked up curbside so disposing of it is a non-issue. I generally check the level after I run it a little bit to distribute the oil through the system. I do not bother with pre-filling the filter in any of my vehicles. It would be a massive PITA to do it in the truck with the idiotic filter location.
2015 Cummins Ram 4wd CC/SB
rhagfo
Grit Dog, you must be bored today!
I have always checked after changing. I check as needed between changes, the Ram uses about a quart between 10K changes so about once a month.
