Jun-07-2022 04:23 PM
Jun-13-2022 01:16 PM
mkirsch wrote:
But if the numbers don't matter, then why do the numbers on the tires matter?
Asking for a friend.
Jun-13-2022 01:12 PM
Jun-13-2022 01:02 PM
Jun-13-2022 12:47 PM
Jun-13-2022 11:15 AM
Jun-13-2022 09:59 AM
Grit dog wrote:ford truck guy wrote:
well......
8 pages of normal RV.Net truck capability arguments and the original OP ( rarin'2go ) was a 1 and done poster on THIS thread.....
I will say that is is/was interesting reading all the response.. what did I learn??
Grit know a TON about trucks and thier capibilities, as do a lot of others..
Cummins HATES IPA
and a Toyota can tow a space shuttle !
Add Grit LIKES IPA to your list of takeaways! Not the trying to be cool with your hipster buds, stifle the bitter beer face like. I just like 'em!
High octane beer! What's not to like??
Jun-13-2022 08:11 AM
well......
Cummins HATES IPA
Jun-13-2022 08:08 AM
ShinerBock wrote:
In regards to the previous comment about tires. I had a family member who bought a 3500 especially for the added payload rating over the 2500 and a week later put large 20" rims and tires that had a load rating about a thousand pounds less than the factory rims and tires which essentially made his truck a 2500 since the tires were the limiting factor.
Jun-13-2022 06:41 AM
ShinerBock wrote:Grit dog wrote:
What’s really funny and to share, while protecting the identity of the guilty, is one person, who fits the bill in the above category apparently, got so wound up over their position, or maybe my position which was contrary (and correct btw ;)) they cussed me out privately!
To that person and those like you, you should take a step back and if something like this thread causes you enough anger or frustration to lash out like you have turrets, then maybe find something else to do, as it’s not healthy for you to participate in this game!
Btw sorry _______. I only try to provide the best info for folks who are asking a question and admittedly aren’t well read. The collateral damage comes with choosing to dis spell the uninformed wrong answers, objectively and with fact, in an effort to steer the person with the honest question in the right direction.
WOW! I don't think I have ever been that into an online convo to cuss someone out in a PM. Don't get me wrong, I will post massive posts to prove my point(if I have nothing better to do at work) or if I feel I am right about something, but to spend the time to cuss someone out in a PM is on another level.
In regards to the previous comment about tires. I had a family member who bought a 3500 specially for the added payload rating and a week later put larger 20" rims and tires that had a load rating about a thousand pounds less than the factory rims and tires which essentially made his truck a 2500 since the tires were the limiting factor.
Jun-13-2022 06:05 AM
Jun-13-2022 05:42 AM
Jun-13-2022 12:00 AM
MFL wrote:
^^Made a great start to my day Grit! That is hilarious! Nice of you to share! I have to say, while you may have been unjustly cussed out in this instance, it only makes up for when you should have been cussed out, and were not! 🙂
Jerry
Jun-12-2022 12:46 PM
spoon059 wrote:BurbMan wrote:
You obviously know more about trucks than I do...I do not know for a fact that the axles on a 2500 and 3500 are the same. I only posted the results from my trip to the scale and compared them to the ratings on my truck and the ratings published for a 2500.
I've been contributing to this forum since 2001, 11+ years before you joined, so if anybody is trolling it's you. The OP asked a question about weights and you're trying your best to turn this into an argument.
I believe that ratings are there for a reason, you obviously think they are concocted for political reasons have have no basis in fact. As my Dad used to say, "You're entitled to your opinion, no matter how wrong it may be."
The ratings are for warranty and registration purposes only. You can register a Tacoma to 14,000 lbs and load it up and be perfectly LEGAL, though I doubt it would move very far.
There used to be a larger mechanical difference between 3/4 and 1 ton trucks, but the manufacturers long ago realized that it is much cheaper and easier to put essenentially the same rolling chassis under either truck and change the spring pack and the sticker on the door to meet the DOT requirements for a class 2B truck.
The spring pack is easy to overcome, with helper springs, Timbrens or air bags.
The sticker can simply be ignored and your truck registered for whatever weights you are willing to pay.
My Ram has AAM 11.5" axles in the rear. They are rated to 12,000 lbs by AAM, derated to 7,000 lbs for the 3500 and 6,500 lbs for the 2500 with 18" rims, and 6,000 for the 2500 with 17" rims. Same axle.
The brakes, wheel studs, engine, transmission, rear differential, bumpers, bed, body, tires, radiator, etc are exactly the same. The frame is slightly different, just due to the shock mounts from the 2500 coil to the 3500 leaf. Ram rates the coils at 500 lbs lower than the leaf springs. If that 500 lbs worries someone, they can put bags or Timbrens to make up the difference.
The only reason that truck manufacturers make a 3/4 ton these days is to get into the class 2B market, which only allows a vehicle a max GVWR of 10,000 lbs. You can by a Ford F350 with a 10,000 lbs sticker, does that make it any less capable than an identical F350 with an 11,500 sticker?
Jun-12-2022 04:40 AM
Jun-11-2022 11:10 AM
