Will my load limit handle this
rickhise
On this forum, After lots of help figuring what my truck will handle.
Looks like weight limit is 7700 lbs.
An F150 flex fuel with tow package.
Is it likely I could find a TT, that has opposing slides,
that would fall in this weight range.
I’ll research more about my particular vehicle issues
brakes, Tran, drive train
If such a TT exists.
My question is do any fall in that range an model if u know
26 REPLIES 26
Boomerweps
Based on your factory white sticker you have a 145" wheelbase. It is either the supercab with the 2/3 rear doors and a 6' bed OR a supercrew with four full doors and a 5.5' bed based on the wheelbase.
Per the sticker you have 3.55 rear axle. You said you have the towing package. Actual door configuration (stated two different ways in the three threads) and engine are the remaining variables in order to use the Ford 2014 towing capacity chart. 4x4
Supercab 5.0L 6' bed. 7800# max towing 13500#GCWR
Supercrew 5.0L 5.5' bed 7700# max towing 13500#GCWR
Super cab 3.5 6' bed ecoboost 9700# max towing 14,400# GCWR
Supercrew 3.5 5.5' bed 9600# max towing 14,500# GCWR
7350# is your GVWR. When your truck is near its GVWR, after you subtract that from the GCWR (from the last listed) of 14500, that actually leaves you with 7150# of tow capacity left vice the 9600# from the same chart. So the ballpark estimates based on cargo capacity and tongue weights in this and the related threads were close 😉
Knowing all these numbers and the ones on your factory stickers is good but best bet is to take your fully loaded truck to a set of scales to get the true weights being carried so you KNOW your remaining cargo capacity for tongue weight.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
GrandpaKip
Basic figuring with example weights:
Add up weights of passengers 330 pounds
Stuff in bed and interior 250 pounds
Weight Distribution System. 100 pounds
Total of 680 pounds
Payload max minus above 1604-680 = 924 pounds
This is the max tongue weight you can put on your truck
Figuring at 15% tongue weight = 6160 pounds loaded trailer(Not Dry Weight)
Using 12.5% tongue weight, it comes to 7392 pounds loaded
So, you would be looking for a trailer in the 6000 to 7000 pound GVWR area with the above numbers
That is the Gross Vehicle Weight Rating, not the Dry Weight
Put your numbers in and see where you are
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
rickhise
So with this info when I shop a new unit
What do I look for weight wise this truck will handle as is.
rickhise
CharlesinGA
Look carefully at the tires you have on it now, and see what the weight @ tire pressure, is listed to be. You door placard shows that the truck came with Passenger tires originally, If you are in a position to replace them, I would consider a real Light Truck tire, an example being
MICHELIN® AGILIS® CROSSCLIMATE® LT275/65R18/E 123/120R BSW MSPN 57222...........
or the MICHELIN® DEFENDER® LTX® M/S LT275/65R18/E 123/120R BSW MSPN 09200
Be aware the Defender is being discontinued and some sizes are either old stock or in short supply.
Also realize that if the tire does not have LT directly in front of the size, it is NOT a light truck tire. Michelin does make a LTX Defender in this same size, p/n 36986 which is NOT an light truck tire, despite being in the LTX Defender lineup. Look at the max pressure on the sidewall. true LT tires will be 80 psi, others will be lower such as the one above that is 44 psi.
Get tires that are way overrated, you cannot go wrong.
Charles
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
opnspaces
Navigator II
Navigator II
Cool, There should also be a yellow sticker in the door jamb that lists cargo capacity, can you post that picture as well?
rickhise
opnspaces
Navigator II
Navigator II
to post a picture follow the below link.
Click on the bold "Easy Photo Upload & Posting Web App" to open the posting app.
Drag and drop your picture onto the screen, or use the browse button to find your photo.
A new window will pop up with the address for your picture. Copy this address. To copy you can hold down the left mouse button and drag the mouse pointer across the address including the IMG and brackets.
Once the address is completely highlighted either right click and copy, or if using a windows computer press CTRL C on your keyboard to copy the address.
Come back to this posting and open a new post. Right in the body of the text window right click and paste, or if using windows press CTRL V on the keyboard to paste. Do not use the normal link icons at the top of the window for this, just paste into the body of your post.
Link
rickhise
How do I post pic
2012Coleman
Door jamb sticker says: Total weight of passengers and cargo not to exceed XXXX lbs.
What is the value of xxxx?
Or yes - post a picture of it
2018 RAM 3500 Big Horn CTD
rickhise
rickhise wrote:
Congratulations to this site. Some of you have the best patience
For those of you which help some of us stumble through our issues
Lucky to have u out there
rickhise
home
Full Member
View Profile
Online
Posted: 07/02/19 10:05am Link | Quote | Edit | Print | Notify Moderator
GVWR 7350 pounds
Rear GAWR 3850 lbs
2014 XLT F150 4/4 with 4 doors 2 full size doors. 6 ft bed
I also have Vin #
rickhise
rickhise
home
Full Member
View Profile
Online
GVWR 7350 pounds
Rear GAWR 3850 lbs
I also have Vin #
rickhise
JIMNLIN
Well....its a start.
2014 F150 with a 7350 GVWR.
And the 3850 GAWR number should be a 3850 RAWR which tells us how much weight your truck can carry.
Working from the 3850 RAWR .......these year model F150 rear axle may weigh in the 2400 lb range leaving approx 1450 lb in the bed payload.
You have the truck and the only way you or anyone will know how much it can safely/legally carry is weigh the truck front and rear axles separately. Stay within your trucks axle/tire load numbers.
You indicated a 7700 lb trailer tow number in another thread. This indicates a crew cab 4wd 5.0 v8 from Fords towing guide.
"IF" thats the case then the truck can handle a 7700 lb TT with no issues.
